U Joint issue ????
Old Feb 14, 2010 | 01:45 PM
rbertalotto's Avatar
U Joint issue ????
Over on the Quad 4X4 web site they have this notice:
Axle U-Joint Kits with PREMIUM non-greaseable, factory lubed axle u-joints. The AAM Front Drive Axle used on 2003-2009 Dodge Ram 2500 and 3500 4x4 trucks uses axle u-joints that have a unique lock-up dimension. However, even though the u-joints are very similar in overall size to those used on the Dana axles previously used by Dodge, the u-joints are not interchangeable which has led to some real problems from trying to force u-joints made for Dana axles into AAM axle shafts due to gross catalog application errors by almost all aftermarket u-joint suppliers. Another problem is original equipment AAM brand universal joints have been associated with some durability problems, so until we introduced our QU40765 Axle Joint (QK4597) in 2006, there was no high-quality, properly sized u-joint available for the AAM 925 axle. Now for 2009, we are introducing our New TK40444 Torque King® Cold-Forged, Factory Lubed Universal Joint and TK40446 Torque King® Cold-Forged, Greaseable Universal Joint for your most demanding applications.
So, the question is.....folks are using the following U-Joints in the front axle:
NEAPCO #3-0485
SPICER #5006813
Federal Mogul / Precision #235
Are these correct or are we "forcing" these u joints into our axles?
The Quad 4X4 u-Joints are outrageously expensive for a U-Joint....
http://quad4x4.com/Dodge%20Front%20A...rvice+download
Thanks
Old Feb 16, 2010 | 09:58 AM
Skyd Ram's Avatar
The Spicer 5006813 was desgined specifically for the AAM axles so they fit perfect. Those are all that I use.
Old Feb 16, 2010 | 11:03 PM
mini14's Avatar
http://www.northerndrivetrain.com/pr...I-5006813.html these will be put in next time.
Old Feb 17, 2010 | 07:24 AM
Rednax's Avatar
https://www.dieseltruckresource.com/...s-t259609.html
72dart
Jun 19, 2012 10:42 PM
Coastal
25
Dec 6, 2009 03:45 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
