U-Joint
Old Dec 21, 2008 | 06:05 PM
lilbluexj's Avatar
U-Joint
I have a u-joint that is bad at the front right wheel. I was wondering how much work it would be to change myself? I usually work on my jeep but haven't had to do anything this much on the truck yet. Just normal maintenance stuff. Or does anyone know a rough price it would cost to have it replaced? Thanks
Old Dec 21, 2008 | 07:20 PM
good ole boy's Avatar
i just had mine done
it was about $400 canadian at the local Mechanic
mitternocht's Avatar
I had a shop do one for me on a truck for around $225. The hardest part about doing it yourself is removing the hub bearing. Sometimes they are rusted in and will split if you user a puller. I guess guys press them out from the back with the power steering too.
Old Dec 21, 2008 | 07:40 PM
cowbizzoy's Avatar
Power steering trick worked for me - took a couple hours a few beers and saved a few hundred...
pm me if you need more details...you can do this...
Old Dec 21, 2008 | 08:11 PM
shineboy2's Avatar
I've done one in mine and one in my dad's. They're not too bad, but you have to be patient getting the hub out. If you're mechanical you'll be fine, if not, take it somewhere and bite the bullet.
Old Dec 21, 2008 | 11:16 PM
lilbluexj's Avatar
My biggest worry is messing up the bearing. Not really wanting to spend an extra $180 on a new one. If the power steering can aid in removal I might give it a try. Have a friend that's a Peterbuilt mechanic if I need some extra help. Thanks
Old Dec 22, 2008 | 05:33 AM
Jeff in TD's Avatar
A member named Mr. Gadget did a great writeup on changing ball joints, which would also show you what is involved, and illustrates the power steering method...
https://www.dieseltruckresource.com/...=1#post2210979
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
drecu
May 16, 2003 09:18 PM
