Turbo Replacement
Old Mar 18, 2010 | 09:05 PM
swampdiesel's Avatar
Turbo Replacement
My brother's stock turbo went down on his 06. Dont really know any details but he says its done. My question is how difficult is the repair/ replacement? Any special tools needed? Looking to do it ourselves just dont want to get in over our heads. Im comfortable working on most anything, except the trans, which I leave to the professionals. Any info/pics/etc is GREATLY APPRECIATED!
Old Mar 19, 2010 | 05:50 AM
tlloyd's Avatar
Hardest thing are the 15mm mounting nuts two on top two underneath.
The job can be done with regular hand tools. 15mm. 12mm,10mm nuts and bolts. You will need a long extension to get to the two 15mm mounting nuts from underneath the truck. Its also much easier if you completely remove the battery and air box. Its a pretty straight forward job. Good luck. Do'nt forget to pre-oil the bearing before you hook up the oil feed line.
Old Mar 19, 2010 | 09:05 AM
Thanks for the info! Can the pre oil be done just by pouring into the inlet of the turbo prior to hooking up the line? Ill be buying a used stocker, so I wont have any sort of instructions, just going for it. Thanks again!
Old Mar 19, 2010 | 01:44 PM
tlloyd's Avatar
Thats how I done it. Just as long as you get a little oil in and the turbo does not start dry.
Old Mar 20, 2010 | 10:38 PM
eot's Avatar
eot
Just changed mine on 06 last night took about 2 hours. I mdid not remove manifold. I split mine from the manifold. Piece of cake except for the dam metric sizes and dont drop the drain line bolt in the motor mount like I did. took some time and swearing to get it out!! Dont forget oil.
Ada381
Feb 10, 2008 07:58 AM
gofastman
Dec 20, 2005 08:12 AM
451Mopar
13
May 2, 2005 09:35 AM
tool
Dec 16, 2004 11:57 AM
cLAYH
Jul 16, 2004 03:31 PM
