tune up
Old Jan 12, 2006 | 08:43 AM
StrokeThis2500's Avatar
tune up
i have almost 60,000 miles ive had it since febuary 2004 (36,000miles) ive only done the normal maintence on it should i do anymore??? If so what????
Old Jan 12, 2006 | 10:01 AM
farmer dave's Avatar
Yeah, you should check the plugs and wires Just kidding. If you have any questions about maintance then check out the owners manual. They have a schedule of what needs to be done.
Old Jan 12, 2006 | 10:04 AM
Chip's Avatar
Just keep on doing your normal maintenance according to the owners man. and you'll be fine. A "tune-up" on our trucks usually means a valve adjustment, I think these engines don't call for a valve adjustment until around 150k miles. Just make sure you change the fuel filter regularly, I change mine every 8k miles with my oil, I run Amsoil, so my drain entervals are a little longer. Some folks change their fuel filter sooner, but just don't ever go over 15k miles on the same fuel filter.
Chip
Old Jan 12, 2006 | 03:13 PM
TexasCTD's Avatar
Prob about time to change those spark plugs!!
Have you been servicing your differentials and transfer case? I probably go a little overboard, but I change my oil and filter every 5k. Fuel Filter ever 10k. And Differentials, transfer case, and tranny fluid/filter every 15k.
Old Jan 12, 2006 | 04:56 PM
PurNLoud's Avatar
if you run a straight pipe(turbo and nothing else) a valve adjustment is not a bad idea, but take it to a well rep. shop, the dealer will charge ya twice as much
Old Jan 12, 2006 | 08:50 PM
underwoodtransp's Avatar
I was told by my tech that if I bring mine in to the dealer at 99000miles and have a complaint of a ticking sound coming from the engine the dealer will warranty the valve adjustment....
Blake Clark
21
Aug 21, 2012 12:35 PM
highrpms
Mar 16, 2008 08:35 PM
hellotbone
Apr 24, 2003 11:02 AM
J.R. Adkins
Jan 14, 2003 07:34 AM
