Truck wont start..no codes or engine light?
Old Jun 26, 2008 | 10:05 PM
sallyman1's Avatar
Truck wont start again. It has new rail pressure sender and FCA regulator. My quadzilla says 9 psi lift pump pressure when i turn key forward. I just filled it up with diesel at station. Could it be bad fuel or plugged fuel filter? No codes or lights?
Old Jun 26, 2008 | 10:44 PM
bandaid's Avatar
Had the same problem last Saturday. Dealer replaced the fuel pressure relief valve and all is well. Pump worked but couldn't build enough pressure because the valve was stuck open.
Old Jun 26, 2008 | 11:39 PM
sallyman1's Avatar
it started now. i drained a lil fuel out of the fuel canister petcock. Then purged it again and it started? water in fuel?
Tsutter
Mar 16, 2012 05:11 PM
sallyman1
Jun 26, 2008 11:40 PM
sallyman1
May 20, 2008 04:43 PM
qcstunter
Jan 9, 2007 04:10 PM
ISBPWRdRam
Apr 20, 2006 04:12 PM
