Truck running HOT! Is it time for a new Cummins?
Old May 30, 2010 | 10:46 AM
1985cucv's Avatar
yeah just spray some water on it if you look at the fan area you can see what i mean. ill look for the thread about cleaning it. just stay on here for a little bit
Old May 30, 2010 | 10:51 AM
BigDodge1's Avatar
Originally Posted by 1985cucv
take a hose and spray the inside of the radiator they get jammed with bugs and such just keep rinsing it. dont do it when its hot there is a thread on here somewhere where a guy pulled his out and it was really dirty. i just spray mine once in a while with a hose. also make sure the radiator is full, after a flush it will be low sometimes.
you could have air in the line somewhere i dont know if these trucks bleed it on their own?
the fan clutch could be broken?
the trans could be getting really hot and not allowing the coolant to cool down all the way?
rad cap could be bad, water pump could be bad, thermostat, you could have a head gasket issue. check all the fluids in the truck to make sure they are not over full! also
I will buy a new rad cap too but how would I know if that was bad? Gaskets were all done at the shop wen they changed everything after the pump went out.
I double checked the tranny fluid and it does not smell burnt but it looks like dirty oil. It no longer has the reddish tint. I will change that out and hope that helps.
Old May 30, 2010 | 10:52 AM
Jeff in TD's Avatar
Also make sure the coolant mixture was correct.
If you got too much antifreeze (by quite a bit) that can actually cause over heating.
Old May 30, 2010 | 10:54 AM
1985cucv's Avatar
for some reason i cannot find it?
dirty fluid is really bad in the trans. you should do a search on removiing the check ball in the trans line that may help your cooling issues. the trans fluid should be changed every 15-20 k miles. i have a built trans now and am going to do it once a year i dont drive it all that much. but just make sure you change that make sure your fluid is topped off. the thermostat is super easy to change it is three bolts and its out pop the new one in and there you go. the radiator caps have been known to just go bad.
Old May 30, 2010 | 10:56 AM
BigDodge1's Avatar
I have a bulb checker for the radiator and I am actually a little bit water heavy
Old May 30, 2010 | 10:59 AM
BigDodge1's Avatar
No problem 1985cucv. Thanks for looking but I got the gist. Truck has cooled off over night and so I will spray this morning.
Old May 30, 2010 | 11:00 AM
1985cucv's Avatar
how much heavy? i think more water cools better. also the additive water wetter will decrease temps it is not a gimmick. the temp will prolly remain close to the same but for some reason it dissipates heat much more rapidly. i used it on my 12vavle that had a cooling issue (due to no fan and it was a mud truck) and it kept is substantially cooler.
i would definitly remove the trans check ball and change your fluid asap otherwist you may be in the market for a new trans and believe me you dont want that!
Old May 30, 2010 | 11:06 AM
RJ285's Avatar
I would be looking at the thermostat myself. I know I've put one in backwards before and it causes the same effect.
Old May 30, 2010 | 11:07 AM
Fordzilla's Avatar
Originally Posted by BigDodge1
I will try cleaning the outside as it has never been cleaned and is full of rocks, bugs, and gunk.
I'm sure you know this, but it's worth repeating: Spray from the inside...If you spray from the outside, debris will just get trapped deeper in the radiator fins......Ben
Old May 30, 2010 | 11:09 AM
BigDodge1's Avatar
about 60/40 water/fluid.
I will do some research about the check ball.
Old May 30, 2010 | 11:13 AM
BigDodge1's Avatar
I will try top down, upside down, inside out, on one foot, and holding my mouth every which way; hopefully that will get it.
Old May 30, 2010 | 02:40 PM
tryNto's Avatar
Originally Posted by NickBeek
If the trans is slipping at all, it will also cause the truck to over heat.
This is where I would look...
Old May 30, 2010 | 03:01 PM
WhiteMule's Avatar
^^^^ Me Too^^^
Old May 31, 2010 | 05:02 PM
quadman20's Avatar
I know I had similar issue on my lower mile truck. Found that T-stat only opened slightly so It was running 210 all the time. Now new T-stat and 190 now
Old May 31, 2010 | 05:11 PM
CUM4X4MINS's Avatar
On the Trans issue: When is the last time you adjusted your bands?
