Trouble code P0341
Trouble code P0341
Had my yellow engine light come on yesterday for a little while. Did not stay on too long. Ckecked for codes. P0341 came up. Anyone have a clue what this code means?
Mine threw the same code last winter, after the engine failed to start at 30 below zero (block heater falfunction). The code would not reset (even pulled battery cables off for several hours), and had to be cleared by scantool. It hasn't re-occured, but I have a spare sensor in the glove box just in case.
I found this post while searching the answer to a problem I'm having. I have a p0341 code and have tried replacing the cam position sensor, no luck. Then I spent an hour on my back wire looming and taping the wires that rub the AC compressor, no luck! I just a had a cam installed and the engine WAS pressure washed due to an oil leak that had gotten everywhere. Why would pressure washing the engine cause this code, and how can I fix it?
That is where I would start.......
coope3
Dec 15, 2008 02:39 PM
Steve V.
Nov 30, 2008 03:10 AM
