Transmission Upgrades
Old Jan 2, 2010 | 04:27 PM
D45's Avatar
D45
I am going to be pulling the trans, hopefully by March, and am slowly collecting all the parts needed.
Daily Driver, Will tow a 6,000 pound deep-v fishing boat 3-4 times per month
Never will sled pull
Never will see the 1/4 mile track
I need to order some more parts....
So far, I have:
BD Black FlexPlate
Opie Billet Input
Mag Hytech Double Deep Trans Pan
Billet 4.2 Apply Lever
Billet Strut
Billet Front Servo Cover
Where can I get other parts or do I need other parts like a billet front drum,
billet servo, billet kickdown, carbon band, etc
I will soon be purchasing a Goerend valve body and Goerend triple disk torque converter, but is there anything else?
THANKS!
Old Jan 2, 2010 | 05:21 PM
no_6_oh_no's Avatar
Add to that list:
Billet front band anchor
Billet rear servo (must have!)
Billet front servo (you will get the good cover with it and if everything else is billet...)
High energy rigid front band
If you are building for longevity and firm positive shifting, don't use kevlar on any of the frictions. Check on the carbon fiber and how grabby it is. It will wear longer with just high energy material.
Unless you are going big power you don't need the billet front drum or any other hard parts. The parts to put 5 clutches in the direct drum would be nice but not neccessary if need to make choices.
Old Jan 2, 2010 | 05:33 PM
D45's Avatar
D45
Originally Posted by no_6_oh_no
Add to that list:
I just need ONE band anchor for the entire trans?
SO there is just ONE front and ONE rear servo?
I did check on the carbon bands (is this the "high energy rigid front band that you are talking about or no?).....how many bands does the stock trans use, or how many bands will I need for the rebuild?
Old Jan 2, 2010 | 05:35 PM
D45's Avatar
D45
http://www.transmissioncenter.org/new_patc_products.htm
Sonnax Dodge 16% Oversize Intermediate Super Servo, Servo Cover and Pin. Fits 727, 46RE, 47RE, 48RE, 518, 618, 46RH and 47RH. New eight sealing ring design for a super seal. The overall result is more holding force in 2nd, firmer 1-2 and 2-3 shifts that become firmer under load
Is this what I need?
Old Jan 2, 2010 | 05:44 PM
no_6_oh_no's Avatar
That would work nicely, or, go here and search for #3S2 and #3-618 rear servo. All are better than stock and will address the leaks form higher pressures.
http://www.transmissioncenter.net/dodge.htm
Old Jan 2, 2010 | 05:50 PM
no_6_oh_no's Avatar
Only the front band use and anchor, the rear band sets up differently and has beefier parts.
Yes, you have a front (intermediate) servo and rear(low\reverse) servo.
On the page you referenced, search for #4NR and #4N. I THINK the #4N is the one you want but I would call and make sure. Kevlar bands are REAL aggessive, not sure about the carbon fibers. They may be between kevlar and stock material.
Old Jan 2, 2010 | 06:19 PM
D45's Avatar
D45
What about 4 ring pistons?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Jan 2, 2010 | 06:20 PM
D45's Avatar
D45
How does this kit look?......Oversize Intermediate Super Servo, Servo Cover and Pin
Old Jan 2, 2010 | 06:22 PM
D45's Avatar
D45
I bought this one
Old Jan 2, 2010 | 06:24 PM
D45's Avatar
D45
Old Jan 2, 2010 | 06:26 PM
D45's Avatar
D45
How many bands are needed for the entire trans?
Old Jan 2, 2010 | 06:27 PM
no_6_oh_no's Avatar
Yep, anthing is better than OE with increased pressures.
Thats the same as on PATC page, in fact its a PATC product on Ebay. Better than OE and has the o-ring for the cover. Will probbaly do all the billet one will do in your application.
Yep, thats the anchor
Yep, thats what I and most use.
Old Jan 2, 2010 | 06:30 PM
no_6_oh_no's Avatar
Just those 2, front and rear. I would go with the carbon fiber if nothing else.
I emailed PATC to get the low down on the differences. Will forward any answers I get on the material types and use.
Old Jan 2, 2010 | 07:59 PM
D45's Avatar
D45
Ok, so:
(1) Reverse Band
(1) Rigid front band
(1) Performance Rear Band Servo with Pin
(1) Heavy Duty Band Anchor
(1) Oversize Intermediate Super Servo, Servo Cover and Pin Kit
(1) Billet 4 Ring Accumulator Piston
Are the quantities what I need?
Anything else on the list?
Old Jan 2, 2010 | 08:30 PM
no_6_oh_no's Avatar
Looks good added to your first list.
