Transmission Conversion/Replacement
Old Aug 30, 2007 | 10:37 AM
Big Rig's Avatar
Anybody every change out their six speed and replace with an auto? Doesn't seem to difficult, maybe a little pricey.
Old Aug 30, 2007 | 11:13 AM
mjsandt's Avatar
Ive only heard about a auto going to a manual. But, it could be done. The body and chassis are the same. DOnt know what would be required, but I think it could be done, like you said, probably pricey. MY $.02.
M Sandt
Old Aug 30, 2007 | 11:54 AM
Hounddog's Avatar
On one of the OTHER Dodge sites is a post about doing such with photos,steps etc.Did not seem to bad of a job.He even addressses what shifter to use and so on.He took out a nv5600 and installed I think a full race HTE??? trans.It wasn't on DTR or TDR but one of the other sites.It was a excellant write up and good photos as he went along.Saw it recently just can't remember which one
Old Aug 30, 2007 | 12:03 PM
Need95-00CTD's Avatar
Prolly need new crossmember, driveshafts, ecm, some wiring, steering column, maybe even a pedal assembly, selling your truck and buying one with an auto seems like a lot less work, and probably less money too.
Old Aug 30, 2007 | 12:13 PM
Big Rig's Avatar
If you remember the site, please advise. Sounds do-able.
Old Aug 30, 2007 | 02:45 PM
Hounddog's Avatar
Actually no add.wiring or ecm. or steering column.I'm going to see if I can find the site.
Old Aug 30, 2007 | 03:27 PM
How is there no difference in the wiring, ecm, or column. The shifter for an auto is on the column, so you'd have to at least change that unless you went with a B&M shifter on the floor. And the wiring to the transmission is different for an auto and a manual...unless I'm missing something obvious. The ECM controls the stock trans, so that'll have to be reprogrammed at least, unless you go with a standalone controller which is mucho` dene`ro.
Old Aug 30, 2007 | 04:17 PM
Hounddog's Avatar
If I remember correctly no reprogram and a wire run to the TPS? He used a aftermarket shifter that fit right in the orignal area and in the console etc.I tried finding the thread and lighning storm hit.I'll try somemore.Middl of the night just looking at other sites and reading articles.The truck was a white 4x4x4 dually and write and photos were excellant.He was doing it in his car port! It looked a lot easier doing the manual to auto then from auto to manual.He was surprized that it shifted good and comminted it needed a minor something done for shift points or???? I need to find the post/threads.
Old Aug 30, 2007 | 05:46 PM
ptgarcia's Avatar
I read a post where someone did the same. I though I read it here on DTR? I think the total cost was around $8000.
Old Aug 30, 2007 | 05:47 PM
nathan04's Avatar
Jeff K did it here's the thread.https://www.dieseltruckresource.com/...ion+conversion
I was going to do the swap, but decided to buy a different truck with an auto.
Old Aug 30, 2007 | 06:07 PM
Hounddog's Avatar
I want to say it was on www.cumminsforum.com but I can't find the thread.Still looking.Any how thats the same deal and shifter etc.
deepsouth06
Feb 20, 2007 01:24 AM
AggiePhil
17
Oct 19, 2006 06:18 PM
demolition_x
Apr 10, 2006 03:52 PM
MasseyMan1089
Aug 4, 2005 10:27 AM
