trans cooler return line (which one ??)
Old Jun 23, 2006 | 12:46 PM
ckennedy's Avatar
which one is the trans return line.. coming off the cooler.. also it is the 2 alum lines on driver side by front tire (when you are under the truck)??
Old Jun 23, 2006 | 01:07 PM
no_6_oh_no's Avatar
Output line is the front oneon the trans, return line is the one that runs to the rear of the trans. Yes, drivers side aluminum lines. Trace them from the trans to make sure.
Old Jun 23, 2006 | 01:29 PM
ckennedy's Avatar
My biggest problem I can't lay on my back very long right now.. my stomch isn't feeling very good right now!
if it is the 2 alum lines (under the left hand side of radiator) you being under the truck.. is it the outside line or inside line?? outside being the one closest to tire..
Old Jun 23, 2006 | 02:03 PM
staarma's Avatar
Here is a pic if it helps.
Old Jun 23, 2006 | 08:21 PM
ckennedy's Avatar
the alum lines I was looking at up front are the power streeing cooler/lines..
ps: the flare nut on the trans line at pan.. can't you just unscrew the larger nut - or do you have to loosen the smaller one.. IT IS JUST A FLARE CONNECTION isn't it??
Scotts_D250
Jul 10, 2011 01:05 AM
isb07
Nov 18, 2009 05:12 PM
ctd4stan
May 18, 2009 02:56 PM
RHC
Nov 22, 2007 08:52 AM
vc
Aug 11, 2007 12:08 PM
