Tranny service , now low speed surge
Old Jul 29, 2007 | 03:25 PM
  #31
sickandtwisted's Avatar
I'm not familiar with the computer updates what do they include
Old Jul 29, 2007 | 09:41 PM
  #32
vzdude's Avatar
DTR's 'Go to Guy'
Basically "fixes' that were either not noticed when the vehicle hit production, problems that arose after some wear, who knows!? I just know I have fixed a ton of vehicles that had odd little nuisnaces with flash updates. Tip in stumbles, unnecessary CEL, surge with cruise - you may not even notice a problem that these updates will point out, but it'll be gone afterwords!
Old Jul 29, 2007 | 10:27 PM
  #33
isbeinside's Avatar
the experiances i have had with this concern, is that the governor soleniod valve R/R in the TSB only works for a short time, it is a software issue that DM has not been allowed to fix because the governor pressure is a emission standard, the hunt from one/two gears is do to the rise and fall of line pressure compared to governor/throttle pressure.
i have fixed this concern by raising line pressure high enough to overtake the throttle pressure drop, (about 1/2 turn on the line pressure set screw), i basicaly make a DIY shift kit.
Old Aug 31, 2007 | 12:52 PM
  #34
rjg23's Avatar
Is this something I can do on my 04.0? Im going to do a DIY service starting tomorrow morning. Change filter, adjust bands, DIY flush, then maybe turn this set screw just under 1/2 turn.
Is the set screw readily accesible, or is this inside the VB, really not looking to go there.
What else could/should I do? Thanks!!
Old Aug 31, 2007 | 04:34 PM
  #35
Seelow's Avatar
Wow thats the same problem I have had with my trans. But its been untouched now wtih 25k on it. I'm going to have to bring it in so it can get fixed under waranty. thanks for the post.
Old Aug 31, 2007 | 08:15 PM
  #36
isbeinside's Avatar
yeah it is easy to get to with the pan down, its located on the driver's side front corner on the trans, it is a 3/16 allen screw, you will probly have to get some channel locks on it, unless you have a super short allen wrench.
this is a basic Trango shift kit minus the springs but does the some basic thing, as long as the line pressure is raised just a bit, 1/2 turn, everything is cherry.
let me specify, though, i can does this under warranty with correct paper work, this specific repairs ARE NOT COVERED UNDER WARRANTY! as this is a MODIFICATION of factory components!
Old Sep 3, 2007 | 08:26 PM
  #37
ROOSTER108BM's Avatar
1/2 turn in or out? I cant see any reason for letting them perform tsb if its not permanent. And Im sure not against fixin it myself
Old Sep 6, 2007 | 08:02 PM
  #38
chancey's Avatar
Guys i'm having the exact same issue with my 06, with 26000 miles on it, although I have not brought it in yet, nor performed the 25K service, it only started doing it after I hooked up a bully dog to it. I've also got the monitor on my truck and my tranny temps have never gotten above 120 degrees. I was at a loss about this, but it seems to be fairly common, Please enlighten me on the fix for this. Or should I just jerk all the Bully dog stuff out and bring it in for warrenty work?
Old Sep 6, 2007 | 08:44 PM
  #39
isbeinside's Avatar
refer to post #36.
Old Sep 6, 2007 | 08:52 PM
  #40
wreedCTD's Avatar
what is the TSB number?>
Old Sep 7, 2007 | 12:02 AM
  #41
blkt6's Avatar
Would a performance valve body fix this, I thinking of going suncoast with a TC.
Old Sep 8, 2007 | 08:55 AM
  #42
chancey's Avatar
Now i'm assuming that you would turn that screw in a half turn, Correct? In order to raise the line pressure. Thanks for the help guys, this is a gr8 place
Old Sep 8, 2007 | 06:56 PM
  #43
My truck feels like it already has a shift kit a real sloppy one too. Along with the low speed surge as well. I'm not to in to the do it yourself stuff on this truck so what are my options.
Old Sep 9, 2007 | 05:16 AM
  #44
Turning the screw counter clockwise increases pressure, while turning it clockwise lowers it. One complete turn changes line pressure 1-2/3 psi
Old Jan 18, 2008 | 05:31 PM
  #45
After four times to the two dealerships they finally found the problem and who would've guessed it was low solenoid pressure. I only told them that on the second visit and brought a copy of the TSB the third. But, they're the proffesionals right... Let's see how long it lasts.
