Tranmission shifting problems
Old Feb 26, 2010 | 08:33 AM
railroaderone's Avatar
My tranmission would not shift into any gear yesterday except 4th unless the engine was shut off it done this for about 15 min and then after I got it up to speed it was fine. The clutch master cylinder was full .
I have been having some clutch slippage issues but only when running with a fully loaded trailer up hill tring to exelerate.
any help would be appericated
Old Feb 26, 2010 | 08:31 PM
robert78.5's Avatar
Is there any noise when you push clutch pedal down? Maybe pilot bearing or release bearing are gone.
Old Feb 27, 2010 | 06:31 AM
no noise if I let it off the floor about 1/4 in it helps a little
Old Feb 28, 2010 | 12:43 PM
littlebigtruck's Avatar
May also want to check the transmission oil level, and check for any sign of abnormal wear in the oil. Robert may also be onto something. How many miles are on your truck? Does it still have the dreaded dual mass(crap) flywheel? If it was mine I would pull the transmission and clutch, then investigate things.
Todd401
20
Jan 23, 2019 11:02 AM
EClancy
Aug 13, 2005 11:18 AM
Reelay
Aug 31, 2004 04:54 PM
Lenn
Jul 7, 2004 02:09 PM
baldeagle
Sep 29, 2003 10:33 AM
