Tow/Haul
Old Dec 12, 2006 | 05:01 PM
NUN YAH RAM's Avatar
Tow/Haul
I have a 2004.5 Ram 2500 Automatic with 3.73 gears a 6 inch lift and 37" tires. There are 15,000 miles on my truck. Is it safe to drive around EVERYWHERE ALL OF THE TIME with the tow/haul mode on until i have enough $$$ to get a gear change?
Old Dec 12, 2006 | 06:33 PM
bluepp's Avatar
On your truck you really dont have a tow haul. What your tow haul does is lockout your 4th gear. Just like all previous years OD OFF setting . Starting in 05 tow haul was a tow haul.
Yes you can run indefinetly with your overdrive locked out , but why???? Doesnt make any sence to do that. Unless your towing in conditions that dont like 4th gear .
Old Dec 12, 2006 | 06:38 PM
bluebull's Avatar
First, welcome.
Fuel mileage will also suffer.
Please explain why you would want to drive around in T/H mode.
It could actually make an auto transmission last longer but is it really worth it.
Old Dec 12, 2006 | 10:08 PM
no_6_oh_no's Avatar
Ahem...Automatic with 3.73 gears a 6 inch lift and 37" tires
THAT is a recipe for a toasted transmission. Without some VB mods I give it about 20k of stop and go driving for the forward and direct clutches to be slipping and showing signs wear.
Less with power mods and/or a heavy right foot.
Old Dec 13, 2006 | 07:39 AM
TurboTed's Avatar
Where did that Post on the OD Lockout kit for the 05's go to?(I did a search) I'd like more info., and possibly to order it.
Old Dec 13, 2006 | 12:30 PM
bluepp's Avatar
www.dieselperformance.com 1-800-887-5030
BD diesel makes the OD lockout for 05 models
Old Dec 13, 2006 | 03:34 PM
Thanks for all of your help but i am still confused, Will using OD off mode make my trans. last longer or have a shorter life span?
Old Dec 13, 2006 | 03:58 PM
ptgarcia's Avatar
Longer life span.
KenandCarolW
Jun 28, 2004 11:56 PM
wengerda
Jun 11, 2004 11:10 AM
wengerda
Jun 4, 2004 08:14 PM
tony
13
Jan 25, 2004 04:10 PM
SongDog
Jan 4, 2004 07:57 PM
