too much oil??
Originally Posted by MikeyB
Might have been overfilled at the factory. Did you smell the oil to check for diesel fuel? If you do take it back to the dealer ASAP, bad injector(s).
MikeyB
MikeyB
No it diden't smell like diesel. Just to much oil but ill check again just to be sure.
to much oil?
Originally Posted by Booboo
When i checked th oil it was about 1" over the hash marks
is that normal. Truck only has about 1200 miles on it so no oil change yet.
is that normal. Truck only has about 1200 miles on it so no oil change yet.Better to be safe than sorry, get your high oil level checked by the dealer to determine if there is anything causing the level to increase. It may have been overfilled at the factory. I first changed my 15W-30 factory petroleum oil at 2303 km/1431 miles on the odometer and replaced it with 10W-30 petroleum oil for the winter to continue the engine break-in period.
If you fill with oil until the level is at the full mark you will be putting in too much. It takes a long time for the oil to drain to the pan on these engines. When i fill after a change i stop about half way on the hash marks, after it sits overnight it will be very close to the full mark and i top up if necessary. I also leave it sit overnight before draining, it's amazing how much oil the block holds.
rob
rob
Mine was overfilled a 1/2 inch or more as well. No diesel smell. I drained some off. It's amazing how black this 06 oil is compared to my 03. Seems to be normal in 04 and up according to a lot of these posts. I hope so.
When I change mine, I put in a total of 3 gallons of Shell Rotella T which is including priming my new oil filter. That always puts it right at the top of the hash marks on the dip stick. Don't these blocks all hold the same amount of oil?
bobinyelm
13
Mar 4, 2010 08:19 PM
jjrightmire1973
Nov 20, 2008 08:20 AM
