Ticking under the hood under load......
Old Jun 10, 2003 | 04:46 AM
Dodgezilla's Avatar
Does anyone else hear this while they are driving? Maybe it's normal. I wish they would have left the engine a little louder so we couldn't hear every little noise.<br>It sounds like my valves need to be adjusted but the truck runs great..
Old Jun 10, 2003 | 11:30 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Re:Ticking under the hood under load......
Mine has an occasional tick at idle that you can hear...which is always followed by the RPM's either slightly lowering or slightly raising. I don't notice it while under load though. I just figured it's some kind of computer something or other doing it's thing....
Old Jun 11, 2003 | 10:44 PM
pwabbott's Avatar
[quote author=Dodgezilla link=board=20;threadid=15715;start=0#147659 date=1055238370]<br>Does anyone else hear this while they are driving? Maybe it's normal. I wish they would have left the engine a little louder so we couldn't hear every little noise.<br>It sounds like my valves need to be adjusted but the truck runs great..<br>[/quote]<br><br>Dodgezilla, <br><br>Is it when you are starting to accelerate from a stop? What RPM?
Old Jun 12, 2003 | 07:08 AM
Dodgezilla's Avatar
I don't really notice it from a stop. It does it when I'm cruising at any rpm. It is a kind of faint ticking which increases in speed as I accelerate. When I let off the accelerator, it goes away. It's not real loud and as I said previously, these new CTDs are a bit too quiet so you hear every little thing. The truck runs great and I will worry about it if I break down..... [undecided]
Old Jun 12, 2003 | 08:19 AM
pwabbott's Avatar
I think most 03 owners hear some tick, tick ticking. Mine is much more obvious like when cruising up a 7% grade. With the clang clang clanging of the 1st &amp; 2nd gens gone. It is easier to hear the melody of the more delicate sounds of the 3rd CTD.<br><br>Enjoy the quietness, now you can hear your favorite CD.
Old Jun 12, 2003 | 12:05 PM
Dodgezilla's Avatar
Right on.. Although, once you get to rolling, you don't even notice how loud the 2nd and 1st gens are..
Old Jun 21, 2003 | 12:04 AM
mennis's Avatar
I am hearing the exact same thing in my '03 HO CTD. It is a faint ticking that increases in speed as I excellerate and stops when I let off of the excellerator, just as Dodgezilla describes. I hope this is a normal sound. This is my first diesel and I am not used to their sounds and idiosynchrocies (not sure on the spelling)
Old Jun 21, 2003 | 05:05 AM
Dodgezilla's Avatar
Yes, the ticking increases in speed but not in volume mennis. I'll worry about it if it gives me any problems.....
Old Jun 21, 2003 | 06:39 AM
mennis's Avatar
I agree with you. The only thing I find a little weird is that I do not recall hearing this the first 1000 miles. I have approximately 1700 now. Of course this could just be the fact that I had not assimilated all of the neuonces and sounds of my new truck. It is nice to know other people are hearing the same thing I am. I certainly do not see any change in the performance which as you know is fantastic. I traded in my '03 hemi for this truck and am very glad I did. <br><br>Mike
Old Feb 12, 2004 | 03:26 PM
Douglas's Avatar
Found this in the TDR web site:
http://www.turbodieselregister.com/f...threadid=81370
my '03 H.O. had the tick at idle since new. it sounded fine at higher rpm's but always came back at idle. I found a cure and it's not pretty. Turns out that the H.O. has a notch in the bottom of the piston on one side to allow clearance for the oil cooling nozzle jet. if a piston is installed with the notch on the wrong side, the piston will lightly tap the oil nozzle on the down stroke and make the tapping noise. This was the case with mine on #5 cylinder. chryslers fix was to replace the short block @ 10,000 mi.. there was no damage to the original block that I could see. after 18 days in the shop the truck is back together and I have put 1,100 miles on the new engine and it runs the way it was designed to.
My 04 has the same tick after starting but seems to go away after warming up. It has been to cold for me to really check thou.
Old Feb 13, 2004 | 04:43 AM
Dodgezilla's Avatar
Wow,
You picked an old post to respond to Douglas. I haven't even noticed the ticking since the time of that posting. i guess it was just breaking in......
Old Feb 13, 2004 | 12:07 PM
sawboywv1's Avatar
If the piston in wrong was a serious ISSUE... I think Cummins would have issued a TSB. Mine only rattles every once in a while and that is the clutch disc. Cummins is a very well organized company with a outstanding track record on performance and durability!
Old Feb 13, 2004 | 03:40 PM
joel's Avatar
I posted about this a while ago. I hear it very faintly at highway speeds. However, engage the cruise and it ticks away like a clock. Kind of annoying, actually.
nvr-enuf
14
Apr 20, 2013 12:59 PM
1985cucv
Apr 11, 2010 10:42 AM
sallyman1
23
Feb 18, 2009 09:46 AM
carwash
Sep 12, 2007 11:39 AM
blackwolfram
May 26, 2007 01:26 PM
