Stock Engine EGTs
Old Jan 4, 2004 | 11:49 AM
Casey Balvert's Avatar
Question Stock Engine EGTs
For those of you towing heavy 14,000 plus with stock 2003 HO engines and a six speed and equipped with gauges, what EGTs are you noting when pulling a load? I am trying to evaluate the need for gauges and measures for reducing EGTs when I tow my fiver. Obviously if EGTs don't go that high, I won't need to do anything. Thanks.
Casey
Old Jan 4, 2004 | 02:44 PM
RCW's Avatar
RCW
I have only seen 1,100 on a long hard upgrade pull with a heavy trailer.
Old Jan 4, 2004 | 09:06 PM
1BadDzl's Avatar
Hey Casey I saw 1150 max going up an 8% grade in 6th at 55 before I downshifted. That the highest I could get. I have the AFE 7 intake and was towing 14700.
Old Jan 4, 2004 | 10:42 PM
Jim O's Avatar
Hey Casey
I installed my pyro after the turbo (like the class 8 on hiway trucks do). I think it is the best place for a unmodified engine. In about 25000 towing Kilometers @ 20500lbs gross weight. I have seen the Pyro at 1000 degrees F only three times. One was pulling north from Stovepipe Wells in Death Valley and you go from -5ft. to about 6500ft above sea level in fourteen miles. The ambient temp that day was 88 degrees F.
I also hit 1000degrees in the Smokey Mtn.s from Pigeon Forge to Cherokee NC.
I installed the thermocouple in my exhaust brake between the turbo and the ex brake butterfly valve. Interestingly enough I have seen 700 Degrees F coming down a long grade.
My reasons for doing it this way are as follows
1 you do not have to remove the turbo or take precautions not to contaminate the turbo.
2 That is the way that Kenworth, Peterbuilt. Volvo, & Freightliner all do it.
The disadvantage is the price of the skinny little gasket that you have to get between the turbo and the Jacobs Ex brake the part # for the gasket is 4089324 and the price was $53.12 Canadian.
Hope this helps
Jim O
Old Jan 5, 2004 | 12:03 PM
tobyw's Avatar
Well first off, mine is pre-turbo. The debate on which location is better rages on...
Second, I have hit the 1350* range with as little as 8000lbs behind me, so I firmly believe gauges are necessary. With over 22k rolling down the road, I really have to watch the EGT's pulling the hills. There are a lot of times where I have more go pedal, but the EGT's hold me back. You learn to drive via the gauges, and not the "performance".
In my opinion, gauges are mandatory. Just my $.02, though
Old Jan 7, 2004 | 01:19 PM
vernl's Avatar
I'm post turbo and have barely touched 1000 on occasion,,usually see 850 to 900 at 24 psi boost on long hard uphills
Old Jan 7, 2004 | 03:40 PM
Yup, I think I will need a pyro. Pushing 1000 degrees post turbo is getting up there. Thanks guys.
Casey
ClackClack
Apr 11, 2011 09:34 AM
SpeedyWS6
Mar 11, 2010 10:19 PM
1985cucv
22
Feb 21, 2010 12:56 AM
kuhkuhkyle
Oct 7, 2007 09:12 AM
panama
Aug 28, 2006 06:16 PM
