Sticking gear shift on 48re getting worse
Here's a pic. of the "clip" location under the steering column (to be adjusted) sent to me by Mpracehemi. Not sure if this will be the fix or not, but I'll post it in case someone else wants to try it. Now that I think about it, I remember reading in a post quite awhile back about the rooster comb having to be filed and worked down to make it smoother. Zuki Dan, is this a big job, or can the average wrench give it a shot? Does the VB have to be removed?
I pet my truck from time to time....
No go. Tried the "clip adjustment" and didn't really see what there was to adjust. The clip looks like a retainer for the housing around the arm plunger(?) that slides up and down in the housing when shifting. As for an adjustment, it's either on (clipped) or its unclipped and ready to slide off. So, not sure about this, but after rowing the selector up and down a few times, I can't see what it's hanging on. There's a silver cable going to the tranny (I assume) but it doesn't move either when shifting. Not sure what else to look for except to go with the rooster comb at the VB. Still looking for a solution.
Thanks MP. Now I see what you meant. So what gear did you try to adjust it in? Leave it Park and barely move it? or another gear? Does it matter? Just doesn's seem like enough play in the shifter to hold it in a new position while reattaching the clip. Maybe a two man job? It would be nice to have this fix the problem. Really getting to be a pain. Oh BTW, I'm wondering what would make it stick only sometimes though if it's just in the column. This is definitely intermittent and doesn't matter if I'm level ground, parking break engaged first, or whatever. Sometimes it's smooth as butter no matter what; and other times I've got to go Hulk on it.
I haven't been in there for awhile, but is there a way to shoot some lube down the cable housing?? Maybe some graphite, wd-40, or white lithium grease. Just another thought, the cable might be 'hanging up' inside. I don't remember if there's any room to do that or is it sealed by the 'plunger'-cable housing??
You might try un clipping the clip and push up (with lever in park position) on the clip as sliding it back home or pull the plunger down as sliding clip home or vise versa. I played with mine for awhile until I found the sweet spot and haven't had any problems since.
On my racecars' throttle cable I shoot the white grease inside the housing from time to time to keep it operating smoothe. Maybe this would help on the shift cable in your situation??? For me it's better for me to do it rather than taking it in and the dealership doing it, IMO they'll just screw something up plus charging you for labor. Added benifit is learning your truck on how it works. That's how my mind works. I've pulled many motor and trans. in cars but when doing my truck, the eng. block extends to where you norminally loosen the conv. bolts and I'm like where/how?? I finally followed the back of block up and found a removable plate to access the conv. bolts. So now I know and so do others who read this. There is always away, just gotta find it after all it was put together.
I hope this helps, after my rambling.
Good idea on the "lube" (if I can gain access inside the housing). I'll try that with a silicon, wd40, and graphite mixture. Maybe add a little bacon grease too, and make it a one finger shift.
Since I was going to be gone over the weekend on my motorcycle, I left my truck in the hands of a capable tech. He detached the cable from the tranny and found that the lever moved in and out of park very easily. He sprayed inside the tranny where the cable attaches (sorry I can't describe it very well, I wasn't there) with a penetrating oil spray very liberally. It's much, much, better, though I may find it to be a temporary fix. YMMV.
Thanks...
This is what I did to adjust my shift. lever. I have not had any problems. When I replaced mt trans. and it wouldn't go completely into park and they darn reverse safety HORN would go off. I called ATS and this is what he told me to do and it would also cure the hard getting out of park problem which I knew nothing of until I read it here a couple of days ago.
If anyone tries this and it doesn't work, let me know so I won't keep telling this to someone else.
