start then dies
Old Jan 17, 2012 | 06:25 PM
e.neale's Avatar
start then dies
Ok so I have a 94 ram 3500 turbo diesel, about a week ago started having issues with starting. What happens when I start it, it runs for about 5 or 6 seconds then dies, after about 3 or 4 minutes of cranking and several start and stalls it starts and runs strong, I can start and stop with no issues, this only happens after it sits for several hours. Going to change the fuel filter, unless some one else has an idea of something else thanks for any help.
Old Jan 18, 2012 | 08:00 AM
Gatorama's Avatar
Welcome to the forum. Filter is a good way to start, and that might fix it, but I suspect you may have a leak in the fuel line on the suction side of the pump that is allowing it to loose its prime.
Old Jan 18, 2012 | 02:31 PM
e.neale's Avatar
How would I go about checking that? Putting the filter on today fingers crossed. Thanks for any help you give.
Old Jan 18, 2012 | 03:25 PM
e.neale's Avatar
ok now went to change the fuel filter(autozone) according to the book there should be a water in fuel sensor on the bottom of the filter, the new filter has a spot for it however the old one doesnt, the old one is a napa #3391 and just look like a plug, first should i just go buy the napa one, or is this an issue
tfdcruiser
Apr 12, 2020 01:26 PM
90 power ram
Oct 6, 2011 08:04 PM
jdddually
Jun 16, 2011 09:18 PM
xfeastonarsex
Feb 5, 2007 05:35 PM
BarryG
Nov 25, 2005 04:53 PM
