Spicer U-Joints for an '06?
Old Dec 14, 2011 | 04:59 PM
ShouldBFishin's Avatar
The greasable precision U joints I put in about 40K miles are toast (I greased them every 5K or so).
I'm thinking about putting in the Spicer 5-1410X non-greasable but...
According to Dana-Spicer tech support, they will not fit. Looking at the dimensions, the cup is the same diameter (1.188") but the Lockup Yoke diameter is .010" bigger.
I know others have ground off .005" off each cup - I'd like to know how they did that (did you just take it to a grinding wheel?) and how they've held up.
If that was a major pain or they didn't hold up I may just end up going with the Neapco 3-0415.
Who's done it and how did it work for you?
Thanks,
Brad
Old Dec 14, 2011 | 05:58 PM
Spooler's Avatar
They make Spicers that fit correctly. Don't remember the part number. Any good driveline shop should be able to hook you up. Precision u-joints are junk.
Old Dec 14, 2011 | 07:02 PM
ekk33's Avatar
I ground mine on a surface grinder and a v block.
If it was possible I would measure the groove distance on the yoke and grind them to fit.
I ground .007 off mine and the clips were a pain to put in.
I only have a couple thousand miles on them so far, no problems.
Old Dec 14, 2011 | 10:24 PM
no_6_oh_no's Avatar
Spicer 5-801X - Auto trans
Spicer 5188x - Manual trans
Old Dec 14, 2011 | 11:12 PM
I was told the 5-1410x is the new version (with improved seals) of the 5-801X. The 5-801X has the same dimensions, which is .010" too wide.
I talked to a guy at a drive line shop - he said that there are rumors about a new u joint specifically to fit the 03 and newer Dodge Rams, but I think I heard that a couple years ago too and have yet to find it.
With a holiday road trip coming up, I'll probably end up with what ever I can find locally knowing that I'll have to change them out again within the next couple of years
Igor
0
Jan 25, 2007 08:40 PM
ocsurf16
Nov 18, 2006 04:16 PM
chip hayden
Jun 15, 2006 09:37 PM
abc4yew
Oct 27, 2005 08:39 AM
JohnnyH
Jul 19, 2005 06:54 AM
