Speedometer Issue
Old Apr 11, 2009 | 03:15 PM
squirlchasr919's Avatar
Speedometer Issue
I ralize this has been addressed in other threads but I thought my particuliar case was a little wierd. My truck has had 35" Tires on it since I had it, I recently switched back to a stock size and now my speedometer reads high, as much as 10mph off on the innerstate. I understand it's a software issue but my truck has no programmer on it so why would it be off?
At any rate I guess my only fix would be to buy a Smarty to correct it?
Old Apr 11, 2009 | 03:21 PM
steelblitzkrieg's Avatar
DTR Detective
Whomever put the 35's on probably calibrated the speedo.
Old Apr 12, 2009 | 06:26 AM
Isn't that done through a programmer though? The truck had a diablosport programmer on it but I removed it completely, I reset the unit to stock tuning when I removed it and sold it. You would think that would have put the speedometer back as well right?
Old Apr 12, 2009 | 09:01 AM
RamWheelsBy4's Avatar
It can be done at a dealer service department with their diagnostic tool. Some dealers charge for this, some don't if you are a regular maintenance customer. They charge anywhere from $35-$75 to reprogram. Cheaper than buying a downloader that can do it.
Some auto/diesel shops have tools that can do it also.
Smarty is one of three or four downloaders than can change the programming for stock tires.
Old Apr 12, 2009 | 08:44 PM
billie's Avatar
The ECM does the speed, the programmer was used to change the ECM but the programmer doesn't calculate the speed itself.
dan123dbl
Feb 13, 2015 05:47 PM
dr450r
Oct 17, 2012 11:34 AM
apwatson50
Apr 22, 2012 10:12 AM
DDysput
May 5, 2004 07:44 AM
