Sounds like a backfire or miss
need more info on year of truck? mine does the same thing and has since brand new and only does it when cold and the grid heater cycles on and off
Do you get any smoke? white, black? Does it go away? Does the exhaust smell like antifreeze? Are you making oil? Have you replaced your fuel filter?
If its cold enough, the 2nd gens have the 3 cylinder high idle. My 2000 would sound like a rod was coming through the side of the block when it would kick in and would kill the engine. But the engine has to be 0F or colder for it to kick in I believe.
My 6.7 now sounds like a jet engine spooling up when the engine brake is turned on warm up through the open pipe (my neighbors love me).
Mine has a tendency to do this also when cold, sounds like it stumbles while warming up, normal or high idle, doesnt seem to make a difference. Thought it was connected to the cp3 "timing" issue I think i have.
Ditto min dose the same thing. Have had it to the dealer a couple of times for different things and told them about it twice and they checked it out and found nothing. Even after reflash.
My 03 rig use to do this until I got the 'low power' flash (I think it's the most recent flash from DC).
It sounded like an engine flutter, wasn't a full miss.
Had something to do with the timing and fuel delivery of #6 cylinder (and possibly #4) as when #6 was disabled the condition didnt change (any other cylinder the condition got worse).
The 'low power' flash doesnt state anything about correcting this condition but does, along with remodulating the throttle pedal and adding a little more top end (at least on a stock truck).
...it's worth checking out with DC to see if the 'low power' flash is applicable to 07 rigs.
Ron
Ron
I had a similar condition with mine. It also "ticked" a bit too much at certain speeds making me feel that an injector might be on its way out. I'm a bad boy in that my commute is only about 3mi each way - so, while my particular usage of the truck is considered very light, it's actually very hard on the engine.
So, I found a thread on this forum that led me to try Howe's Meaner Kleaner fuel treatment. I thought it might help to clean the injectors. Anyway, the improvement was nearly instant. I'm sold on this stuff and just ordered another 4 qts. from Ryder Fleet Products. I toss in 8oz with each fill-up and the engine has never run better.
I complained about mine to the dealer and each time they checked it they told me i was on crack (very good friend is the service director) UNTIL I was hired there and one night after work we were all around and mine was on high idle (did it on high idle or normal idle) and it POPPED and he turned and looked at me like WHAT WAS THAT! I was like HAHA! There it is and you heard it yourself crack head! Our disctrict rep heard it too and he was floored.
