Sometimes rough idle at startup
Old Jul 15, 2012 | 05:22 PM
Geary's Avatar
I'm new to the diesel world. Three months ago I bought a stock 2003 Ram 2500 4x4, auto tran, 5.9L with 190,000 miles. I have put 5,000 miles on it. I have changed out one injector at 193,000 miles. Since then on about 3 occasions after sitting over night my starting problem has occured. It starts quick goes to 750rpm, and then drops to 500rpm as if it is choking. Then it surges to 1000rpm, and drops back to a smooth 750rpm. Only one time did it die, and I had to start it up again. This problem has only occurred after sitting over night. Your suggestings will be appreciated. I am not a mechanic; I'm a 71 year old cowboy in Oklahoma.
Old Jul 16, 2012 | 06:13 AM
Pull Dog's Avatar
I had this exact problem with my 2005 when I bought it used with 22,000 miles on the odometer. After two or three trips to the dealer and two injectors and a harness replacement the problem continued. I decided to try Diesel Kleen found at Wal-Mart. I immediately had no further problems with rough idle. Now I use the prescribed amount each fill up. The injectors must have been clogged up or something because Diesel Kleen resolved my problem immediately and this was nearly 4 years ago!!
Old Jul 16, 2012 | 07:24 AM
Geary's Avatar
Thanks Pull Dog
I'll give it a try, and hope it works. I could buy a lot of Kleen for one injector!
Old Jul 16, 2012 | 04:37 PM
bdewey's Avatar
Another possible problem is your FCA on your CP3 pump. It has been know to fluctate fuel pressures and cause same problems, but with 193,000 on the truck and stock injectors they are tired and need to be freshened up.
Old Jul 16, 2012 | 08:49 PM
Geary's Avatar
Thanks bdewey
For the past few weeks I've been reading through this forum when I have time, and I've wondered if the FCA could be part of my problem. When I can get into town, and find a diesel mechanic I'll have him check it out. They way that a diesel works, I could have more than one cause and effect. I enjoy reading this forum. It's very helpful for an old man like me.
crwlaway
Apr 15, 2012 06:04 PM
isxalso
Nov 23, 2008 08:31 AM
deerezilla
15
Jul 30, 2008 10:37 PM
Ridiculous
14
May 21, 2007 09:11 PM
jerry007
Jan 6, 2007 08:01 PM
