slack in the drive line
Old Nov 28, 2005 | 08:10 PM
epenn03's Avatar
I've had my truck since april,and have done alot of pulling with the truck. I have noticed the last several times that I have pulled my trailer,which a 24 ft flat deck 6700lbs empty,that when I am going down the road at a smooth speed and let off of the fuel there is kind on a jerk in the truck.Ithought that it might be the trailer but when I pulled my cattle trailer it done the same thing.when I am empty it is not as bad,just when I get on it hard.Any help would be great. I done like the book said and waited until the truck had a 1000 miles before i pulled and the broke it in slow to heavy weights. Thanks
05 ctd 3500 drw 6spd 3.73 all stock except silencer ring
Old Nov 28, 2005 | 08:15 PM
G1625S's Avatar
Check over your motor mounts and tranny mounts. You could have one prematurely wore, or perhaps not properly bolted down from the factory. I have a Detroit locker in mine, which has a lot of lash built in. Just by making my own tranny mounts 80% of that lash was gone(meaning, of course, that the lash was actually in the tranny mounts...). Also check for loose u-joints in the driveshaft. Hope this helps...
Old Nov 28, 2005 | 08:23 PM
epenn03's Avatar
hey thanks for the input. I will check on that. You would think that a new truck you would not have to worry about loose motor mounts and u joints with under 10000 miles. Has any one else out there had this problem?
Old Nov 29, 2005 | 08:41 PM
bluebull's Avatar
Yup, there is alot of slack in the drive line on the newer trucks. Alot of discussion about U-joints.
Old Nov 29, 2005 | 09:56 PM
jwtuc's Avatar
Mine has been that way since new . Not happy with it either . Can not get service dept. to do anything about it .
Old Nov 30, 2005 | 04:15 AM
AirGrabber's Avatar
If it just started happening, and wasnt doing it before, you probably have a bad u-joint. One way to tell is to take it for a ride then get under the truck and feel them. The bad one (ones) will be a hot or hotter than the others. How many miles on your truck?
Old Dec 1, 2005 | 05:20 PM
epenn03's Avatar
it seems that the 05 trucks have this problem. My truck currently has 7500 miles on it. I contacted the dealer about this and they seemed to think everything was normal,go figure. Still would hate to think that a new truck would have bad u joints.
Old Dec 2, 2005 | 07:19 AM
bluebull's Avatar
I don't think it's all U-joint related. There is alot of stuff in the drive line and if each or a few have a little slop it adds up to slop you can feel. Transmisssion to transfer to drive shaft to rear end and all the U-joints in between.
93Dodgeman
May 20, 2006 06:26 PM
tyssniffen
Feb 12, 2006 03:20 PM
wannadiesel
Sep 21, 2004 07:04 AM
Lambo
May 21, 2004 10:14 PM
INsIdious
Apr 8, 2004 06:56 PM
