Simple question about lubing
I am doing all my maintenance and will be greasing the tie rod ends and the font UV joint with the needle probe fitting. My question is, what type of grease is everyone using? I don't want to go with some cheap stuff by accident so i figured i better find out from the pros on whats the right good stuff to use. Also how many pumps are you guys getting in the tie rod end zerk fittings w/o blowing the boot?
Thanks
Eric
Thanks
Eric
I use the marine type grease, I figure it will not wash out as well as the regular type. You can buy it at wal-mart for less than most places and is not more expensive than regular grease.
I agree with Bull..
Find a good Aluminum Complex grease and stay away from lithium (soap based) grease.
It has better reversability meaning it sucks back in to an area after it has compressed due to pressure or shock.
It has a much higher film strenght which means that it holds up longer under pressure and heat long after the Lithium greases give up.
It won't wash out...
And it is completely compatible with other greases so you don't have to worry about mixing them. >> Because who is going to clean the old stuff out?
I switched about 4 years ago and notice a HUGE difference on usage...
I maintain about 2500-3000 vehicles and some pretty large fleets and my usage dropped by almost half!!! The biggest place I noticed is in Ujoints on big rigs... They normally take about 30-35 shots with Lithium grease... they now take 15-20 after 6-10K miles... I have also seen a reduction in Ujoint and Carrier bearing failures.
Speaking from experience... I use a specific brand and it is not that much more expensive that the name brand Lithium grease that I was purchasing.
I use Scheaffer Specialized Lubricants Brand... #229 Moly Ultra
I only have 1 complaint about it... The red die seep out if the case is left upside down... other than that... great stuff.
I have been using lithium grease, since that is what the manual called for. I have been using it for the tie rod ends and also for the driveline cardan joint. I usually lube every oil change.
It is carried by dealers... a lot of privately own auto parts shops carry it... There should be a link on the schaeffer site for a local vendor.
I like making more money with the same amount of work.
The factory manual I have specifies that tie rod grease meets Natinal Lubricating Grease Institute's LB standard (the highest standard for chassis grease), but doesn't seem to say anything more specific.
I use Mobile 1's synthetic grease that meets NLGI LB and GC (the highest rating for wheel bearing applications).
I'm sure there are many choices of grease that will provide great protection, but personally I wouldn't use anything that isn't marked NLGI-LB.
I went to the auto parts store today and of course they didn't carry the Schefers grease, but I did pick up the Mobil 1 synthetic stuff, it didn't mention anything about lithium or soap based so I thought that was my best bet. I will keep an eye out for the Schefer stuff though.
snowranger
Aug 15, 2007 03:09 PM
