Signs of a lift pump going bad?
Truck runs great at idle or normal driving, except when I really step on the throttle. It then bogs down like it has ran out of gas, but will go back to normal when I let off.
Truck has about 120k on all original parts. Any ideas? |
Really, no one?
if you changed your fuel filter recently, then i would say your pump is getting weak.
Joe |
getting stranded on road was my sign
Originally Posted by michael/edge
(Post 3018749)
I guess I will order from Geno's unless someone else knows a place cheaper. Better safe than sorry! |
Mine does the exact same thing, and my LP is fine. I'm wondering if it is the FCA.......may try changing that out.
The 03's had the side engine mounted lift pump. I'd say your pretty lucky to get 120,000 out of the original especially with the Edge Juice.
Originally Posted by annabelle
(Post 3018780)
My FCA symptoms were all at idle. Small stumbles and puffs of smoke every few seconds. Ran fine towing and daily driving.
Fuel Pressure gauge would help troubleshoot the LP. |
Thanks for the info.
Found a Carter lift pump for $139 delivered.
Hopefully it will be here soon. |
(Post 3018749)
