Shifting 2,4,6 Only?
Anyone with a 6 speed shifting in 2,4,6 only?
They seem to be about 1000 RPMs apart.
Normaly shifting at around 2200 RPMs unloaded.
Any Thoughts?
Diesel Fool
Any Thoughts?
Diesel Fool
Re:Shifting 2,4,6 Only?
My shift pattern is normally 3, 4, 5, 6.....or 2, 3, 4, 5, 6...depending on the conditions I'm starting out at. I typically shift around 1800 RPMS...and I'm pretty much always unloaded since I have nothing to tow. :'(
I used to do the 2,4,6 thing a long time ago, but usually do the 2-6 routine now.
Like Spots said, shift however it floats your boat. Its all fun and good!
I would wait until the transmission is broken in before skipping gears. Just to be sure that all the gears are lapped in. I started skipping at the 5k mark.
Mikey
Mikey
What is this clutch you speak of?? I only use it to start out, otherwise I float between'em. Might as well save the disc as long as possible, not racing anyone anyway.
Daren
Daren
Guest
Posts: n/a
[quote author=MikeyB link=board=20;threadid=22001;start=0#msg205959 date=1068037709]
Mikey
[/quote]
I have about 2500 miles on mine, and I always start out in second, except when I'm towing. I'm going to start in first from now on for a while until it's broken in right. Seems to work fine though
Mikey
[/quote]
Hey daren, what rpm's for which gear do you float in and out at. Just curious how your gates are set up. Thanks and I genearlly use 2-6 but on occassion exercise the 1-6 or the 2,4,6 just to keep things exciting.
I run about 1800 to 2000 but can slide all the way to 3000 and it still does fine. I am still getting used to sliding down the gears. Going up is easier than down, so far. I have not used 1st very often but the wife does, she cannot get used to starting in 2nd yet.
Daren
Daren
[quote author=Daren link=board=20;threadid=22001;start=0#msg207015 date=1068225912]
Daren
[/quote]
Funny you should say that. My wife will only start out in 1st also. And when I drive her car I stall it in second when my brain is off..duh :
Daren
[/quote]
Boy am I glad to see somebody else talk about stalling a car. I tried to start out in second gear in a Honda the other day. You should have seen the dirty looks I got from traffic. I usually run the gears 2-6.
Jason
Jason
Brendan
Oct 17, 2007 11:12 AM
Vaughn MacKenzie
Nov 3, 2002 07:22 AM
