Serpentine Tensioner and Pulley
Old Aug 14, 2014 | 09:14 AM
jeephauler's Avatar
Im getting ready to do some maintenance and have been noticing a sqeek coming from what I suspect to be the tensioner pulley. I figure I am going to do the water pump, thermostat, coolant flush, and tensioner pulley all at the same time. I see Genos has just the pulleys or the whole assembly. Id rather not get into tearing stuff apart prior to having my parts so the question is do the tensioner assemblies need to be replaced or just the pulley? Im at 84,XXX miles.
Old Aug 14, 2014 | 11:41 AM
chrism69's Avatar
I replaced the whole tensioner. I dont know if you can just get the pulley. Also check the idler, mine had slight play in it so I changed it while I had everything apart.
Old Aug 15, 2014 | 07:15 AM
MikeyB's Avatar
And if you do buy a tensioner get a Gates. The Dayco's are weaker by design and are known to crack.
Old Aug 15, 2014 | 10:07 AM
jeephauler's Avatar
Just the tensioner assembly is weaker? The only replacement pulley Genos offeror is the Dayco, but they do offer the whole assembly by Gates.
Old Aug 16, 2014 | 04:21 PM
MikeyB's Avatar
IIRC Dayco pulleys are made from plastic. Gates are metal. Personally I would replace the whole assembly with Gates.
Old Aug 17, 2014 | 10:04 AM
Greg Reed's Avatar
How do the Goodyear assemblies compare with Gates? They look stout at least by pictures.
Old Aug 17, 2014 | 04:48 PM
Dr.Dizzle's Avatar
The Goodyear and Gates tensioners are the same product. You can get the Gates tensioner at Napa. The Goodyear/ Gates are also available at RockAuto and Amazon.
bobsallyh
Nov 6, 2014 07:33 PM
thames1948
Sep 26, 2007 04:59 PM
banshee
23
Aug 16, 2004 02:20 PM
Commatoze
Oct 24, 2002 09:32 AM
