Sallymans Engine Results....
Old Mar 26, 2009 | 02:21 PM
DBLR's Avatar
Why are you not using a 7 micron or smaller fuel filter in your stock fuel filter housing? I'm sure you have been told about the Baldwin PF7977 fuel filters being 5 micron and fit in the stock housing.
Old Mar 26, 2009 | 03:31 PM
sallyman1's Avatar
did a new test run today empty on highway. there was no wind. i registered 590-600F egt at 100 km/hour with about 2-3 lbs boost.
Old Mar 26, 2009 | 03:32 PM
sallyman1's Avatar
im using the 7 micron. i think the fass is better than the stock system is it not?
Old Mar 26, 2009 | 03:47 PM
Ace's Avatar
Ace
You don't need a $500 pump/filter setup to get good filtering. This head cost me $26 + s&h. Gotta fab your own mount tho, so I 'spose that could be prohibitive.:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CRD_09.JPG
Old Mar 26, 2009 | 05:17 PM
nelrod's Avatar
Glad you got it back. Your numbers sound good to me. And yes, if I jump on mine, the egt's jump up like yours. I don't know about my automatic high idle, I remember when it came up, but don't remember if it automatically idles back down. Sallyman, if you don't have it already, you should go to a Cummins parts place and get the 12 buck pigtail, to allow you to high idle your engine with your cruise control, and go back in till its warm. You can set it to max of 1500. Where you live you would love it. Mine is 6 speed, and I did not have to go to dealer to have it enabled, I guess because of Smarty. Does power seem the same or is it too early to tell?
Old Mar 26, 2009 | 06:23 PM
xtoyz17's Avatar
Congrats! Glad to hear you got it back and its running good! Now have some fun!
Old Mar 26, 2009 | 07:26 PM
sallyman1's Avatar
i enabled my high idle electronically with a drb3 scanner when i was at Diesel school last year.i can go 11-1500 rpm with my cruise buttons.
Old Mar 26, 2009 | 07:28 PM
sallyman1's Avatar
only thing i noticed is when im driving and i lay into it a little the boost climbs good 5,10,15,20 and then it dips really fast to like 18ish or so then goes back to 25 psi and holds it there? is that the wastegate? i ruled out air to air leak because it would never hold 30psi and it does.its like SOMETIMES i get a rapid spike drop in boost but then i gain it back right away.
Old Mar 27, 2009 | 02:34 PM
DBLR's Avatar
BTW, yes it is normal for the engine to idle up and then back down on its own when its cold out, mine as well as other Dodge trucks in my area do the same thing.
Old Mar 27, 2009 | 06:00 PM
CD in NM's Avatar
Originally Posted by sallyman1
thanks for input.cd in nm what do you see if you mildly tromp on fuel pedal? does it kinda sky rocket to 11-1200F?
My EGT's do rise as I increase the fuel, but then I have to shift gears which usually brings them down, then back up throught the next gear. I am guessing that an auto tranny has a different relationship to EGT's than a stick??
I have gotten pretty high EGT's towing when I lug the load and need to downshift, or have been on a relatively constant grade for an extended period of time. Probably 1200*s is the highest constant I have had over a couple miles or so, but I have also been in a lower gear to hold the speed/grade travel constant.
CD
royta
Mar 7, 2011 12:13 PM
sallyman1
71
Mar 1, 2009 07:16 AM
Commatoze
Mar 19, 2003 08:20 AM
nascar mark
Nov 14, 2002 01:29 PM
