Retriving Codes
Old Oct 25, 2006 | 07:50 PM
MudHog's Avatar
Retriving Codes
What do I need to read codes on an 06 ? Is the truck OBD II compatable ?
Old Oct 26, 2006 | 09:55 AM
JohnInNH's Avatar
Ditto... The "on off" 3x thing does not work on the 06. Just gives you "donE"
Does anyone make a code reader/clearing box for the 2006 that does not cost an arm and a leg?
Gas cap and other stupid crap should get cleared so if you get a real CEL you can get the issue fixed.
I would hate to be driving around thinking it's a minor BS CEL when it's really not!
Drove to my dealer after making an appointment to get my CEL read drove the 45 minutes ... To only find out their scan tool has been broken for a week!
what a waste of MY time and MY fuel!
Old Oct 27, 2006 | 03:47 AM
MudHog's Avatar
Tried the OBD II last night and couldn't access anything. Anyone know what dealers are using on the 06's.
Old Oct 27, 2006 | 05:28 AM
P.J's Avatar
P.J
If you are getting "done" that means there are NO codes to display.
I think they use a DRB II at the dealer ($)
Old Oct 27, 2006 | 11:28 AM
cskal's Avatar
I thought that I read that the DRB doesn't work on the 06's; that they had to use the StarScan or something?
Old Oct 27, 2006 | 11:38 AM
P.J's Avatar
P.J
Hmmmm, you may be right on that.
Old Oct 27, 2006 | 01:54 PM
Foxborough's Avatar
When my CEL came on I went to an Auto Zone. I wanted to see of one of their readers could read & clear a CEL. It did and I bought it. It was an Actron Auto Scanner CP9153. It was around $100. I was about to go on a trip and wanted to see if the light was critical or not. It turned out to be the air temperature rational code, it is worth it in my opinion.
Old Oct 28, 2006 | 11:17 AM
Tom282's Avatar
Could the unit you bought possibly be a CP9135? I tried to locate a CP9153 and all I could find was the CP9135. Thanks for your help!
Old Oct 28, 2006 | 03:45 PM
bighornram's Avatar
3X on/off will retrieve codes for an '06 fine - i just did it to see if it would work and it did. And what do you know - i had two of them. Checked with my Attitude and there they were same as the dash read:
P0513 - INVALID SKIM KEY
P0069 - MAP/BARO Correlation
So what do these mean?
P.S. - being able to retrieve and clear codes with the Edge sure is a nice feature. Well worth the money.
Old Oct 31, 2006 | 07:31 AM
JohnInNH's Avatar
Well on my 06 I did the 3x on and off and got DonE with no codes but had the CEL light on... Dealer pulled 2 codes. He told me the 3x on and off will not work for an 06. He cleared them and they have not re appeared. (fan speed and a rail pressure code)
Old Oct 31, 2006 | 09:10 AM
Foxborough's Avatar
Sorry about the AutoScanner Tom282, it is the CP9135 . I just got back from China and just now getting my sleep back. . Just reset the codes for the air rational & battery temperature. Seems to happen in Spring & Fall for me.
Old Oct 31, 2006 | 04:10 PM
Donut Gestapo's Avatar
Question
The 3X Key thing works for my 06 just fine.
Old Oct 31, 2006 | 04:59 PM
goose2's Avatar
It never worked on my 06 also.
Old Oct 31, 2006 | 05:05 PM
Tom282's Avatar
Kevin, thanks so much for the reply! I'm showing 2 error codes right now, one being a P0111 which is a "Intake Air Temperature Circuit Range/Performance Problem", and a P0514, which is not listed on this site.http://www.troublecodes.net/OBD2/Pcodes.shtml#500
I saw the unit you have on ebay for $89.00, and that seems like a good price. Sure beats a 85 mile round trip to the dealer if these are only nuisance codes!
Thanks again for the reply! I hope your China trip went well!
Old Nov 1, 2006 | 06:54 AM
Foxborough's Avatar
The P0514 code is the battery temperature rational. It seems to trip when ever there is a big change in temperature overnight. Usually it has happened in the spring & fall. The other code I have gotten is 0071 ( Ambient air temperature rational).
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
