Replaced CP3-Now that's fun.
Old Mar 30, 2006 | 07:18 PM
jnck's Avatar
Just got done replacing CP3 at 143000 miles.
Took about 3 hours.
No codes, but truck lost 2-3 mpg and could not maintain normal fuel pressure.
Truck is much quieter now and fuel pressure seems normal.
Will put it on the road tomorrow and give update on power.
Cost $1050 + core at local injector shop.
Plus $70 for cleaner,and special tools :
36mm fan clutch wrench
steering wheel puller
serpentine belt tool
Old Mar 31, 2006 | 06:05 AM
rich2500's Avatar
congrats on the do it your self job
Old Mar 31, 2006 | 06:31 AM
jnck's Avatar
Thank-you
If you take your time it really was not that hard.
My back is really thanking me this morning.
Old Mar 31, 2006 | 06:37 AM
rammtuff's Avatar
Steering wheel puller??
Old Mar 31, 2006 | 06:53 AM
jnck's Avatar
You use it to pull the pump gear off the tapered shaft in front.
Old Mar 31, 2006 | 08:21 PM
jnck's Avatar
Truck is much, much quieter.
Excessive black smoke is gone and
overhead is more realistic.
Fuel gauge is still a little funky but I may have fried it when I accidently
put the pressure relief valve in backwards on the holley blue. Over 30psi when you do that on a 0-30 gauge.
Planning to get cheap gauge and check it at the pump.
You cannot believe how much quieter it is.
Old Apr 1, 2006 | 10:07 AM
metal_miner's Avatar
jnck-
What all did you have to remove around the CP3 in order to remove it?
-fan belt?
-intercooler pipe?
-ECM?
-APPS?
-fan?
Thanks!
Old Apr 1, 2006 | 08:59 PM
jnck's Avatar
Unbolt ECM. No disconnect
Everything from the intercooler to intake manifold.
Throttle linkage mount. Infront of intake throat.
Upper radiator hose.
Fan and shroud
Old Apr 1, 2006 | 09:55 PM
Jfaulkner's Avatar
Muted User
you don't have to remove any of that if you have the right tool. Sure it's $30.00 but that fan is a pain, I'd spend the 30 to not have to remove all that crap.
Old Apr 1, 2006 | 10:45 PM
p-pumped's Avatar
takes about 45 min to do swap. do not need to remove any thing accept whats hooked to the pump. on the older third gens that have the apps up top you need to move it. taking the belt loose helps to get to the front of the gear but not required.
ted
Old Apr 2, 2006 | 07:07 AM
rich2500's Avatar
when i did mine all I removed was the upper rad. hose,belt,and ecm,and the lines going to the pump and the fca plug.
red_neck1984
Feb 6, 2008 03:23 PM
RacerDude
Jan 9, 2008 07:24 PM
megacabrule
33
May 10, 2007 01:07 PM
RN1
Sep 25, 2005 10:04 PM
