replaced converter, now problem
Cummins Guru
Slippage indicated by engine flare, usually means clutch or line pressure problems. What trans and year? 68RFE? AS68RC? Might want to have pressure test before condeming the tq converter.
I checked line pressure's before I took anything out. Everything was within spec. Like I said, there were NO issues with the trans, or stock converter before I replaced the converter with this aftermarket unit.
Cummins Guru
Did company give specs on tq converter stall speed RPM? Stall speed will change depending on weight and HP of truck. Also when we install Billeted tq we replace band with kevlar and input shaft with billet shaft.
That still tells us absolutely nothing about the alleged problem. You might get some help if you described what you think is wrong.
al5608
Dec 17, 2011 12:34 PM
JWHenson
Aug 9, 2010 04:31 PM
homermandy
Mar 13, 2010 09:46 PM
F. Flack
18
Aug 10, 2004 06:03 PM
