Removing Turbo
Old Jan 25, 2010 | 05:35 PM
saltfever's Avatar
Removing Turbo
How hard is it to take the turbo off a 2005 5.9 Cummins? Any tricks or tips to know? Ours may have a hot shutdown bearing failure. High pitched tone that is not normal and the turbo has some resistance to spin freely.
Old Jan 25, 2010 | 05:41 PM
tajinate's Avatar
None of that sounds good. They are not hard to take off at all, hardest part is putting them back on if any of it really is that hard, getting the exhaust down pipe seated correctly against the back of the turbo and tightening it down.
Old Jan 25, 2010 | 07:20 PM
dieselfreak21's Avatar
Plenty of penatrating lube.
Old Jan 25, 2010 | 07:38 PM
1985cucv's Avatar
antiseize the studs and loosen the 2 clamps on the elbow so you can line up the dowunpipe when putting it back on and youll be golden
Old Jan 25, 2010 | 07:46 PM
realest's Avatar
use a torch to heat turbo nuts....it will save your knuckles!
i've changed plenty of cummins turbos but none in a dodge.
make sure to prelube the new turbo before install
Old Jan 25, 2010 | 07:47 PM
saltfever's Avatar
Thanks for the information. I believe I'll put some penteration lube on tonight so tomorrow night will go faster.
Old Jan 26, 2010 | 07:18 AM
tlloyd's Avatar
You will need a really long extension on a ratchet for the back 15mm mounting nuts. These nuts are really tight and can prove to be the worst part of the job. I also had to grind a 15mm box end wrench down to get the wrench on the front mounting nuts.
Old Jan 26, 2010 | 02:17 PM
Dodgezilla's Avatar
Yup. That rear inside nut is a real pain to get to. It's 10 times worse with a larger aftermarket turbo......
427AC
Dec 25, 2005 05:04 PM
piperca
42
Apr 18, 2005 12:43 PM
PapaPerk
23
Jan 1, 2005 07:33 AM
ramguy
Jul 3, 2003 07:46 AM
nicksort
Jun 30, 2003 05:51 PM
