Relocated tranny temp sensor
Old Feb 20, 2007 | 02:10 PM
flyfsh70's Avatar
So I have had my tranny temp sensor in the test ports for the last 30k miles, so I decided to relocate it to the hot line right before servicing the tranny so I could have the tranny place fill it up with clean fluid.
I got to say that I should have relocated it sooner. The reading that you get from the test port is very deceiving. First it takes forever to respond, and second I see an average of 35 to 40 degrees higher that I ever saw in the same driving conditions. So for all of you that have your tranny temp sensor in the test port, just consider that you are reading about 40 degrees lower that the fluid that is touching your gears.
Old Feb 21, 2007 | 03:36 PM
SOhappy's Avatar
Yup, I was aware of that. I always add about 40° to mine.
BTW:
Click HERE to join the DTR Tranny Probe Test Port Club!
(just kidding)
RonP
14
Jan 12, 2006 10:05 PM
Bad Ramer Jamer
Dec 3, 2005 09:27 PM
reddawg
27
May 2, 2005 04:47 PM
CTD NUT
13
Jan 4, 2005 04:34 PM
MCMLV
Nov 16, 2002 08:30 PM
