Recalibrating Speedo
Old Jul 26, 2007 | 08:27 AM
whttacoma's Avatar
I am taking my truck in to flash ECM and I want to have the speedo calibrated but I am not sure what the pinion factor should be and I want to double check what they tell me it should be. I have 315/70-17 tires and 3.73 gears on my truck, does anyone know the number that should be used?
Old Jul 26, 2007 | 08:41 AM
Mark Hodowanec's Avatar
603. Varies a little based on what particular tire you run.
Old Jul 26, 2007 | 09:01 AM
06megacabman's Avatar
I believe, depending on your year, they can only go so high. I have an 06 and they can only go to a 285 size ratio max. You may find your speedo still off but better. For my 285/70/17 that factor is 636. If you have a programmer like the Triple Dog or Smarty you can correct the full amount.
Old Jul 26, 2007 | 06:21 PM
bondkx01's Avatar
smarty worked great for my 37's. Speedo is gps spot on now.
woodsRIDER92
Jul 24, 2010 11:00 PM
cvcook
Jun 25, 2010 03:25 AM
mrdrinksalil
Jul 16, 2009 09:18 AM
aggie06
Jul 12, 2008 05:55 PM
JohnnyH
Jun 28, 2008 10:16 PM
