Rear Rotors stuck
Old May 18, 2013 | 10:35 PM
anpconnors's Avatar
Rear Rotors stuck
Trying to do rear brakes, rotors stuck/seized on hub. Sprayed down with PB Blaster. Backed off star adjuster. Hit many times with 4lb sledge. Emergency brake cable adjustment nut rusted (Michigan salt). Getting torch set. Should I heat up cherry red or take out axle/hub? Thanks!
Old May 18, 2013 | 10:51 PM
.boB's Avatar
Had the same problem, but not as much rust in CO.
Put the axle on jack stands, and loosen all the lug nuts. Not a lot, just about 1/8" between the lug nut face and the wheel.
Run the speedometer up to about 40mph or so and slam on the brakes. I had to do that about 5-6 times, but it worked.
Old May 19, 2013 | 09:13 AM
verdesardog's Avatar
DON'T get anything cherry red, it will change the metalurgy of the parts and weaken them!!! Just heat enough to lossen the rust.
Old May 19, 2013 | 10:06 AM
Totallyrad's Avatar
If the 2500's are like the 3500's you can cut all day and you'll only make a mess. Mine were bolted on, pics and instructions in this thread.
http://wiki.dieseltruckresource.com/...en_Rear_Breaks
Old May 19, 2013 | 11:43 AM
anpconnors's Avatar
Thanks for the link! For 2500 no need (yet) to remove axle. Sprayed them down with Kroil and will tap on them. I have gained more respect for the guys who do this for a living!
Old May 19, 2013 | 01:06 PM
Rob's Red Ram's Avatar
Just use a bigger hammer.They will come off don't be scared to hit them like You mean it.I think I had to use a big sledge like 14lbs or so.They came loose.
Old May 19, 2013 | 05:53 PM
anpconnors's Avatar
Thank you for the advise! Time, pen. oils and BFH got the rotors off.
Glad I resisted the torch as that would have added more work in replacing the bearings and seals.
birdboy
Dec 12, 2018 09:02 PM
gmh
Jan 31, 2011 12:05 PM
Baja
Jan 29, 2008 08:17 PM
04ctd
Aug 3, 2007 04:19 AM
04ctd
Sep 14, 2004 04:43 PM
