Rear end code
Old Apr 4, 2007 | 09:54 PM
Ramyes's Avatar
Rear end code
I am new to Dodge and new to DTR, just traded a powerstroke for a cummins. I got about 500 miles on my 07 mega cab drw, I was told by the dealer this truck has a 3.73 thats fine I beileve him. But there has got to be a code on this thing somewhere. I just have to see it for myself.
Old Apr 5, 2007 | 03:12 AM
TexasCTD's Avatar
Congrats on your new truck!!! Welcome to DTR!!
If you truck is a 6 speed manual G56, it definately has the 3.73 rear. That is the only way they come.
If you have an automatic you can order 4.10s, but most come with 3.73s also. It should be on the window sticker somewhere or maybe on a code list in the glove box.
Old Apr 5, 2007 | 09:21 AM
XLR8R's Avatar
Could you fill out your sig, please?
Old Apr 5, 2007 | 08:34 PM
Ramyes's Avatar
I have looked on the window sticker all it says is 11.5 rear, I've looked at every sticker on this thing, researched and read forums. Maybe I'm making to big of a deal out of this but its just one of those things I would like to know.
Old Apr 5, 2007 | 10:35 PM
rockcrawler304's Avatar
If it does not say anything you have 3.73's. If it was 4.10's it would have them listed as an option.
Old Apr 7, 2007 | 10:08 AM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Arrow Codes
Go to dodge.com - use contact them - submit your vin #........ I did.... this is their reply for mne.
Thank you for contacting the Chrysler Group Customer Assistance Center
regarding your 2007 Dodge Ram.
According to our records, your vehicle was equipped from the factory
with the following:
*M9 - Cloth 40/20/40 Prem Bench Seat
-D5 - Med Slate Gray
ADA - Light Group
AF3 - Quad Cab Thunder Road Value Group
AHCP - Trailer Tow Group
APAS - Monotone Paint
BAZS - 136 Amp Alternator
BCQP - 750 Amp Maintenance Free Battery
BRTS - Anti-Lock 4-Wheel Disc Brakes
CBEP - 40/20/40 Split Bench Seat
CGDS - Front Height Adjust Shoulder Belts
CG1S - Next Gen Multistage Front Air Bags**
CKES - Front Seat Area Carpet
CLES - Front & Rear Floor Mats
CSPS - Passenger Assist Handle
CSXP - Rear 60/40 Split Folding Seat
CUES - Rear Underseat Compartment Storage
CUSS - Overhead Console w/Trip Computer
CVHP - Front Center Seat Cushion Storage
CVN - Folding Flat Load Floor Storage
DGBS - All 4-Speed Automatic Transmissions
DG8 - 4-Spd. Automatic 48RE Transmission
DMES - 3.73 Axle Ratio
DRQP - 11.50 Rear Axle
DSA - Anti-Spin Differential Rear Axle
ETH - 5.9L HO Cummins Turbo Diesel Engine
GACS - Tinted Glass Windows
GFDP - Rear Sliding Window
GNCP - Sun Visors w/Illum Vanity Mirrors
GNKP - Rear View Auto Dim Mirror
GNMS - Passenger Side Sun Visor w/Mirror
GTSS - Power Heated Mirrors, Fold-Away
GVBC - All Vehicles W/Power Mirrors
GXMS - Remote Keyless Entry
GXXS - Sentry Key Theft Deterrent System
HAAS - Air Conditioning
HGBS - Dash Liner Insulation
HGFS - Floor Tunnel Insulation
JAYS - Instrument Cluster w/Tach
JBYS - Instr. Panel Color Keyed Bezel
JCBS - 120 MPH Primary Speedometer
JHAS - Var Intermittent Windshield Wipers
JJAS - Cigar Lighter
JJBS - Dual Note Electric Horns
JJJS - 12V Auxiliary Power Outlet
JKYS - Power Accessory Delay
JPBS - Power Locks
JPDS - Power Windows, Driver One-Touch
JRDP - Power Driver Seat
JTHP - Power 6-Way Driver Seat
K1XP - STRIPE/BADGE/MOLDING/COLOR
K17P - STRIPE/BADGE/MOLDING
LBCP - Glove Box Lamp
LBDP - Ash Tray Lamp
LCLP - Front Dome w/On/Off Switch Lamp
LDAP - Underhood Lamp
LMAS - Halogen Headlamps
LNJP - Fog Lamps
LPES - Cargo Lamp
MBFS - Bright Rear Bumper
MCMS - Body Color Upper Fascia
MCTS - Bright Front Bumper
MDAS - Front License Plate Bracket
MFDS - Bright Grille
MGAS - Ram's Head Badge
MHAS - Black Windshield Moldings
MTDS - SLT Badge
MWDS - Removable Tailgate w/Caliper Latches
MXBS - Front Air Dam
NAA - Federal Emissions
NFUS - 34 Gallon Fuel Tank
NHBP - Auxiliary Transmission Oil Cooler
NHMS - Speed Control
NHNP - Electronically Controlled Throttle
NMCS - Heavy Duty Engine Cooling
NZCP - Current Generation Eng Controller
PS2 - Bright Silver Metallic Clear Coat
QS2S - Bright Silver Metallic Clear Coat
RAAC - All Radio Equipped Vehicles
RAQ - AM/FM CD 6-Disc MP3 Radio
RCKP - Infinity Speakers
RDDP - Fixed Long Mast Antenna
RDZP - Steering Wheel Mounted Audio Ctrls
RSAP - Sirius Satellite Radio
SBAS - Power Rack and Pinion Steering
SCVP - Leather Wrapped Steering Wheel
SFBS - Front Heavy Duty Shock Absorbers
SGBS - Rear Heavy Duty Shock Absorbers
SHAS - Front Stabilizer Bar
SUAS - Tilt Steering Column
TBBS - Full Size Spare Tire
TBMS - Tire Carrier Winch
TT3S - LT265/70R17E BSW All Season Tires
TZHP - Michelin Brand Tires
WF1S - 17" Steel Spare Wheel
WGDP - 17X8.0 Forged Aluminum Wheels
WLZC - All Aluminum Wheels
WMJP - Center Hub
XA8S - Non Adjustable Pedals
XBSS - Pickup Box
XCZP - Toluca Painted Cargo Box
XEAP - Tow Hooks
XFHP - Hitch - Class IV Receiver
XFKP - 7 Pin Wiring Harness
XFUS - Trailer Tow w/4-Pin Connector Wiring
XGWP - YES Essentials(R) Seat Fabric
X9AP - For More Info, Call 888-539-7474
X97P - 1-Year Service Provided by SIRIUS
YAAS - Build To U S Market Specifications
YG4A - 5.5 Additional Gallons of Diesel
ZCRP - Spring - Left Rear
ZFGP - Spring - Left Front
ZRRP - Spring - Right Rear
ZUGP - Spring - Right Front
Z2CP - GVW/Payload Rating
1AAS - U.S. Dealer Retail
166S - Zone 66-Orlando
2TGA - Customer Preferred Package 2TG
2UG - Customer Preferred Package 2UG
39JA - Thunder Road Value Group Discount
Hope this helps
2500CTD
Oct 19, 2010 07:10 PM
RichN
0
Aug 6, 2010 06:52 PM
1999blackcloud
Jan 26, 2010 08:52 AM
doorguy
Jun 8, 2007 06:19 AM
royta
Jul 13, 2004 06:54 PM
