Rear driveshaft u joint replacement
so i have a u joint going out on the rear driveshaft of the truck........i have em on order from napa and plan on installing tomorrow if the weathers ok........does anyone have any suggestions on how to make this as painless as possible. thanks
i have done a search but couldn't really find a how to thread or anything.
If you've done them before, no big deal just a bit bigger than most vehicles.
If not get a friends help who has. There are a bunch of pitfalls in u-joint replacement, dropped roller bearings, bent yokes, mushroomed surfaces, etc. A press is handy but a large vise works well.
Here's a link to a play-by-play for rear driveshaft replacement that I put together:
https://www.dieseltruckresource.com/...s-t236691.html
Some important tips are found in steps 11 & 12 if I remember right.
Lemme know if you have any questions.
Yeah find a good local drivetrain specialty shop, drive there.Unbolt said shaft, and have them take twenty minutes while you wait reading a magazine, pay the $10 - $20, bolt the shaft on, and Smile knowing you just did good and saved yourself an hour or more of cursing. Many things are worth doing yourself. This isnt one of them. This is who i use locally. http://www.industrynet.com/info.asp?CID=1145008
Unless you have the specialty equipment, save yourself the time. How much is your time worth to you? If it were a front axle joint id say go ahead as it requires a bit of labor $$ to tear apart.
If this is an excercise in empty pockets, have at least a big bench vise, some BFH's, some pb blaster, couple of worthless sockets, a few beers, and a few hours...
Has anyone had to deal with a u-joint that does not have retainer clips? It appears to have holes filled with wax dots sticking out on each side of each cap, but no clips. There are grooves that look like they should have clips. It's an 06' Dulley Long bed. Been messing with that and trying to get the Pinion Flange off, I was able to remove the Pinion Nut, but the flange seems to be permanently attached. The U-Joint oblonged the Pinion Seal and it's leaking oil all over the place.
Had my driveshaft u-joints changed last month. I tried heat and hammer but was unsuccessful. I took it to a driveshaft shop - cost $37 bucks for them to press out the old ones and put the new ones in. Took about one hour. Well worth it in my opinion.
Be very sure to wear safety glasses during the heating. The plastic can heat up and build pressure while trapped within the yoke, then spurt out the hole with some force. I know of a tech who got some molten plastic in his eye that way. Apparently it's not pleasant. Don't be too alarmed, it was a fluke but it can happen.
I got it done, but won't do it again. Heating helped, and soaking over night with Penetrating Oil made a difference too. It's back in and not shaking anymore, but next time it's going to the shop. Thanks for all the input.
Next time it is going to a shop. Not worth the time and aggravation.
joem
Jul 15, 2011 09:15 PM
krazydher
Apr 11, 2010 02:41 AM
ERuhl
Mar 11, 2009 05:19 AM
