rear diff?
Old Oct 23, 2009 | 07:19 AM
justin allan's Avatar
rear diff?
My pinion is loose (kinda alot) I am going to reabuild the rear diff. Any sug on what should I do??
Old Oct 23, 2009 | 03:02 PM
dodge35000's Avatar
Check backlash, carrier bearing preload, pinion bearing preload, and do a pattern check. Note all of your readings and compare to the factory specs.
If you have over 80K miles replace carrier bearings, pinion bearings, crush sleeve, and pinion nut. Reset backlash, carrier bearing preload, pinion bearing preload, and do a final pattern check.
Old Oct 23, 2009 | 05:18 PM
bansh-eman's Avatar
Dang Mocho when did you learn to speak Russian?
afate45
Jun 7, 2014 12:08 AM
banana
Dec 1, 2009 11:44 PM
papaduck
Apr 4, 2003 09:29 PM
46mech
Mar 8, 2003 07:43 PM
USMC64-70
Nov 10, 2002 02:59 PM
