question on 2007
Old Dec 1, 2010 | 01:23 AM
DIESELWRKS's Avatar
question on 2007
quick question for you I'm sure its the same but should double check have a friend that is not able to do anything on his truck right now so I'm helping. he has a early 07 5.9 was going to change his oil for him and do his fuel filter. my 02 looks the same on the filter but is the micron rating 7ish for the 3rd gen CR, where my 02 is 10micron? and I'm assuming the plastic fuel lid is the same size of socket as mine?
thanks
Old Dec 1, 2010 | 11:49 AM
pull-do's Avatar
thanks
Yep, same size nut on top, 1 1/8",,,, get you a Baldwin fuel filter, 5 micron rating, 3rd gen. needs better filtration to be on the safe side.
Old Dec 1, 2010 | 12:05 PM
ssandlin's Avatar
If you don't have easy access to the Baldwin, the 7 micron from Fleetguard is also acceptable, per Dodge specifications.
Old Dec 1, 2010 | 01:58 PM
DIESELWRKS's Avatar
yep thanks I just got part numbers from Geno's for fleetguard.
Fronty Owner
Nov 17, 2007 12:44 PM
burners_banshee
Sep 10, 2007 02:03 PM
ID2500Ram
Apr 29, 2007 11:31 PM
