Problem found when switching out Fuel filters.
Old Sep 24, 2008 | 09:17 PM
buzzard1's Avatar
After removing the filter, my wife (her hands were small enough to fit) found some sandy grit in the bottom of the filter housing. I guess im asking if anyone else has had this grit build up before. I am hoping this will cure my horrible mpg's. We used a non tearing paper towel that I presoaked in diesel (to make sure no lint came off) to get in there and clean it out. After starting I filled it up and put a full container of Kleen Diesel injector cleaner in. Is their anything else that i need to check now that I have found this mess?
Old Sep 24, 2008 | 09:25 PM
rockcrawler304's Avatar
If it is a brownish black stuff you are fine. I always use a lint free rag to wipe it clean. This is very common.
Old Sep 24, 2008 | 09:29 PM
oilfield-trash's Avatar
the only thing I would check out is where you buy diesel. Only buy deisel at high volume outlets and never fill up when the tanker truck is dumping fuel in the tanks.
Old Sep 24, 2008 | 09:30 PM
klx650a2's Avatar
I've seen the same thing in mine (2000) and my dad's (05). Not sure where it comes from, just clean it out really well and continue. Fuel economy did not change.
Old Sep 24, 2008 | 09:33 PM
buzzard1's Avatar
Cool, I was hoping it wasn't too bad. This is my 4th filter change and the first ive noticed it. I hope my mpg will finally get above 16mpg. The S&B intake has gained a solid 1 mpg. My last trip (before the S&B), cruise set at 67 mph 1850 rpm,no trailer or load and I got 16.4 mpg. My 03 dually would have gotten 20-21mpg on the same trip.
kelley15
Aug 20, 2007 04:52 PM
diesel_kid
Oct 26, 2004 07:45 AM
