Power and mpg drop ???
Old Feb 21, 2008 | 01:48 PM
sdaly's Avatar
Hey guys,
For probably over 3 months now, it seems that my CTD has had less power and a bit poorer mpg than in the past. I have checked about everything and I'm stumped. There's no CEL, no smoke, oil level is fine, temps are fine, turbo sounds normal, and I've changed the fuel and air filters. It's not doing anything else strange other than it feels like power is down a bit and I'm getting a little less mpg. When I'm loaded and pulling, there are some hills that I used to climb effortlessly that now I can feel the truck straining to pull even at full throttle. I'm beginning to wonder if it's fuel, but I've been buying fuel from different stations. I have 75K miles on the truck and the engine is bone stock. Anything else you can think of that I should check? Would a valve adjustment help? Thanks.
Old Feb 21, 2008 | 02:34 PM
jkitterman's Avatar
I don't know where you are located but around here it is called winter and winter fuel. Less power.
Old Feb 21, 2008 | 03:39 PM
sdaly's Avatar
I'm in southern california. Even though we don't really have a winter here, I believe we still do get some sort of winter blend fuels.
Old Feb 22, 2008 | 02:39 PM
DBLR's Avatar
Maybe you need to put a load in the bed or hook to a 6K trailer and heat up the engine to burn out the carbon that builds up on the injectors and on top of the pistons.
Old Feb 23, 2008 | 04:35 PM
Adaminak's Avatar
Tow something heavy
Dead on! Climb a mountain pass or two with a loaded trailer and it'll probably clear everything up. Can't hurt to check all your intake hose connections either.
Old Feb 23, 2008 | 05:31 PM
mitternocht's Avatar
Most likely it is a winter fuel issue; however you might want to look at getting some gauges. Specifically a boost gauge and a lift pump pressure gauge. I believe you have the in-tank lift pump, which is better than what Dodge used in the past, but they can still fail. The above gauges will point out any low boost/full pressure.
Also check/replace your fuel and air filters.
1992gen1_fan
Oct 26, 2011 06:18 PM
Ron R
Sep 16, 2008 11:09 AM
chrisw1173
Aug 23, 2007 08:50 PM
Mark Hodowanec
Nov 10, 2004 06:41 PM
Gene007
Jul 10, 2003 12:55 AM
