Part identification help!!
Old Jul 8, 2011 | 11:47 AM
6spd05Dually's Avatar
My dad found this part which looks like a pressure regulator with a compression spring in a drain pan when he was dumping oil. I sent the pictures to cummins and they said it might be a check valve for the oil pump. I had removed my oil pump on my 05 5.9 and I didn't see a place where this would go. The engine oil cooler has a check valve, but it hasn't been touched. If you know what this is, please chime in. The spring is about 2 3/8" long and regulator cap is 1". Thanks
Attached Thumbnails Part identification help!!-picture-1.jpg   Part identification help!!-picture-2.jpg   Part identification help!!-picture-3.jpg
Old Jul 8, 2011 | 11:55 AM
AH64ID's Avatar
Looks like the oil pressure relief valve.. Thou not sure how it would end up in the pan?
Attached Thumbnails Part identification help!!-oil-pressure-relief-valve.jpg
Old Jul 8, 2011 | 07:11 PM
lol..just got done answering my other post on what you said and here you are again. The guys at cummins thought the same thing, but that valve in the oil cooler is different. This little part supposedly rides in the grooves of the fork shifter on the transmission being I have a 6spd. I dropped the tranny to do the rear main seal/wear sleeve so it must have popped out. I will look at it tomorrow and take pictures and update on my findings in case anyone runs into this issue.
Old Jul 12, 2011 | 10:40 AM
AH64ID's Avatar
But how did it get in the oil pan?
Old Jul 12, 2011 | 04:23 PM
steelblitzkrieg's Avatar
DTR Detective
I think he means the oil collection pan which was used for tranny service previously.
Old Jul 12, 2011 | 04:36 PM
AH64ID's Avatar
That would make a big difference!
Old Jul 14, 2011 | 08:57 AM
I checked the oil pressure relief valve spring etc. That spring is a lot bigger than the one in the picture I posted. We still haven't been able to determine what the part goes to yet. I wouldn't worry so much if it weren't for that cap with the hole that allows fluid to go through.
Old Jul 14, 2011 | 10:11 AM
1-2-3's Avatar
Just a plain ole guy
What vehicles has the pan been used for? Maybe it goes to a different vehicle.
Ozzking93
Dec 22, 2011 08:01 AM
CSAGrey1
Jan 27, 2010 11:30 PM
Ilikebikes
Dec 8, 2006 12:31 PM
billv45
Aug 23, 2006 06:15 PM
cumminsdriver635
Dec 16, 2005 07:58 AM
