PacBrake Lube needed
Old Nov 13, 2013 | 02:11 PM
Danavilla's Avatar
I'm in Yuma, AZ for a couple of weeks and my PacBrake has stuck closed a few times in the last week. I use the brake every day and pull pretty hard at times on hills so doubt carbon buildup is the problem I haven't been able to find PacBrake lube locally here and the local Harbor Freight doesn't stock Super Lube oilers. Any suggestions?
Old Nov 13, 2013 | 02:21 PM
pronstar's Avatar
I wasn't aware that a PacBrake required maintenance/lube...?
Old Nov 13, 2013 | 03:07 PM
ripping r's Avatar
I use air tool oil. may not be the best but has worked for years.
Old Nov 13, 2013 | 07:49 PM
Super Dave's Avatar
Pacbrake makes a synthetic lube to oil the moving bits. You are supposed to apply a few drops to the linkages each oil change.
A few drops of synthetic engine oil should work fine.
Old Nov 14, 2013 | 08:24 AM
Danavilla's Avatar
I'll try some local truck supply's this AM for the PacBrake Lube. If I can't find it I plan to temporarily service it with PB Blaster until I can get the proper stuff sent to me. Should have done it long ago.
mknittle
Mar 11, 2015 10:47 AM
Bad Ramer Jamer
Jun 14, 2008 11:01 PM
dssimecek
Mar 10, 2008 04:58 PM
commando
Mar 16, 2003 08:51 PM
Superduty12v
Oct 14, 2002 10:31 AM
