P2149 help
Old Dec 9, 2020 | 09:18 AM
Jbomb001's Avatar
P2149 help
I have a 05 3500 and have P2149 code with the usual symptoms but with no other codes. I’ve checked everything and checked ohms and all within spec.
I followed a repair guide sent to me and found out I have 4 volts at the plug on high side drivers when key on. I replaced the wiring and still have the 4 volts. What could be causing this?
Old Dec 9, 2020 | 10:39 AM
StealthDiesel's Avatar
P2146/9 are usually death codes for 2003-07 injectors. P2146 refers to injectors 1-3, P2149 refers to injector 4-6.
What is the resistance reading for each injector? This is usually the 1st step. Then check the injector wiring and connectors.
Search for P2146/9 on this forum for a ton of reading on these codes.
Old Dec 9, 2020 | 10:45 AM
Jbomb001's Avatar
I checked everything and injectors are brand new as first thing I thought of, it’s the 4volts on the high side drivers(all 3, pink/tan wires) causing the issue. I already replaced the 3 wires as well right to ecm plug
Jbomb001
0
Dec 8, 2020 09:10 PM
mhuppertz
Mar 3, 2014 08:11 AM
Airdocdodge
May 14, 2008 08:05 AM
BigHornCTD
33
Oct 25, 2007 06:36 PM
soulezoo
Jun 26, 2007 11:09 AM
