P0514
P0514
Hi Guys
Does anybody know what code P0514 is?
I could not find it on the OBD2 list.
Truck is running fine.
Pulled the code with the ignition switch manouver.
Originally Posted by Toto
Hi Guys
Symptom:
P0514-BAT TEMPERATURE SENSOR RATIONALITY
When Monitored and Set Condition:
When Monitored: While the engine is running.
Set Condition: The ECM does not read a change in value from the sensor over time.
POSSIBLE CAUSES
BATTERY TEMP SENSOR
INTERMITTENT CONDITION
TEST ACTION APPLICABILITY
1 Remove the temperature sensor and reconnect the wiring harness connector to the
sensor.
Monitor DRBIIIt, while heating the sensor with an external heat source (DO NOT
USE OPEN FLAME).
Does the reading from the sensor increase at least 5 degrees F. on the DRBIIIt?
All
Yes ! Refer to the INTERMITTENT CONDITION Symptom (Diagnostic
Procedure).
Perform POWERTRAIN VERIFICATION TEST VER - 4 (DIESEL).
No ! Replace the battery temperature sensor.
146
DRIVEABILITY - DIESEL
BAJA MAN
Dec 10, 2005 06:17 PM
billyrae
Nov 19, 2004 06:00 AM
