p0243 and p0480 codes with too much boost??
Old Jan 25, 2008 | 04:07 PM
upjeeper's Avatar
I had a remote start installed on my truck last month and every time i use the remote function my check engine light comes on with p0243 and p0480 codes. Unfortunately I moved from the area before I got it completely resolved (the salesman told me the ECU would learn to compensate for whatever changes occurred in the engine and the CEL would go away). I believed him.
Anyway, i noticed last night when driving home that even on level grade going around 75 mph i was running 12-15 pound of boost. Does this sound right??
*P0243 Wastegate Pressure Control PWM
*P0480 Fan 1 Control Circuit
Could something be wonky with my wastegate?
on yea, the turbo timer doesn't work right on it either, the remote start system has a turbo shut down timer but it only worked in the installers lot. grr...
thanks
nate
Old Jan 25, 2008 | 04:10 PM
_Adam_'s Avatar
Sound to me like the install team tapped into the wrong wires.
Old Jan 26, 2008 | 09:36 AM
sweeney186's Avatar
Blown fuse will also pop those codes-fan & wastegate are on the same circuit
jlindsay
Jan 26, 2013 07:10 AM
PSURPRENANT
Jan 11, 2011 08:40 PM
polk5295
Oct 12, 2010 02:56 PM
sCreamin400
Oct 26, 2008 02:50 PM
tristan21
0
Jun 12, 2006 03:00 PM
