P0191 - Anyone had this and fixed it?
Old Mar 12, 2005 | 08:30 PM
eastmentCTD600's Avatar
Question P0191 - Anyone had this and fixed it?
Just read my codes, the odometer displayed "P0191" which is apparently "Fuel Rail Pressure Sensor Circuit Performance" -?
I looked it up here http://www.autotap.com/codes.asp, is this the right place to find this code, it appears to be a generic OBDII code?
My friggin' code scanner did not pick this up, cycling the key 3 times and watching the odometer displayed it.
Question:
Has anyone had this and and got it fixed?
FYI: My check engine light is not on.
Thanks,
Eric
Old Mar 12, 2005 | 09:01 PM
RN1's Avatar
RN1
My truck had this code when new. I had just read about cycling the key 3 times, that's how I found it. The dealer had never seen it before and called Cummins about it. The paperwork I got from them says " rationality due to A/C high pressure switch wire rubbing on low pressure line. Insulated & rerouted wiring, OK at this time." They cleared it and it has never come back in over 17K miles...........Robert
Old Mar 14, 2005 | 10:31 PM
dodgezilla04's Avatar
Got it after I installed an edge ez and made a few WOT blasts. The next morning upon startup, the code would be there. Took the dealer to clear it, they said they wanted to replace the sensor and star wanted the old one. I didnt want to wait 4 days without the truck for them to receive the sensor. Figured out the box was for an 04, not 04.5 and sent it back. The code has never been back. Good luck.
8Lug_hotrod
Apr 18, 2021 08:07 AM
bigb
Oct 23, 2010 05:41 PM
donnee
Dec 1, 2005 07:57 AM
jwtuc
14
Mar 22, 2004 08:35 PM
