Which one to order?/ How to?
Hello.
I have a 2004 2500 std cab california engine my question is which exaust would i order one for an 04 or one for an 04.5? Since mine does have a cat.
Also i installed a CB in my truck an i was wondering how you guys ran the antenna wire into the cab i have it mounted on the 4x4 shifter plastic bezel
thanks dennis
thanks dennis
To determine if you have an 04 or 04.5, look on the driver side door where the information tag is, if it was built after 1 jan 04, it's an 04.5. The fact that you have a cat tells me that you have an 04.5, but I don't know about CA vehicles. See if the pipe is 4" or 3.5...
Where is your antenna at on the truck? There are plastic gromets under the steering wheel that you can cut and push the wire out, and I think that there are some on the back/under the cab somewhere...
Here's where I run my stuff out to the engine compartment...
cameroneod
15
Aug 5, 2007 02:11 PM
jmccart
Aug 2, 2007 12:35 AM
dealseeker
15
Dec 17, 2002 06:43 AM
