One more oil question
Old Jan 9, 2010 | 05:11 PM
kyman's Avatar
I live in West Ky. It is as cold as it has been in years here. It is about 10-15*F. I have a block heater that I will plug in the night before the truck will be used. For the most part it is not used unless it's racing season (drag racing). I would like to know if it would be ok to run 40w year around. The temps will usualy be 40*-100*F during most of its operation. The truck calls for 15w-40, but I can get the 40w for free. It's Rotella. Thanks!!!
Old Jan 9, 2010 | 06:03 PM
DirtEater's Avatar
The problem with running straight 40W is that it's like molasses at start up while it's cold, and I know what you mean about it being colder than it has been in a long time, we're getting it too. You might consider using a 5W40 right now like Rotella or Mobil1. I wouldn't even rish it. But you might try a pour test with the free oil while it's 10f.
Old Jan 9, 2010 | 06:42 PM
RowJ's Avatar
IF you plug it in for 4-6 hr min before starting it, and
IF you let it fully warm up before you drive even close to hard..... I see no problem.
Heating the coolant well does heat up the block, and in turn does somewhat preheat the oil.
I proved this to my satisfaction when I had an oil temp gauge!
RJ
Old Jan 9, 2010 | 06:56 PM
AkTallPaul's Avatar
Or put a oil pan heater on too...for straight 40w
Old Jan 10, 2010 | 08:13 AM
kyman's Avatar
So for th esummertime, the oil would be absolutely no problem though right? thanks again guys!
cameroneod
15
Aug 5, 2007 02:11 PM
cujo
Feb 2, 2006 08:42 PM
TxDiesel007
15
Jan 18, 2006 01:19 PM
DODGE4X4
Jun 25, 2003 01:54 AM
converteddzlr
Feb 19, 2003 01:28 PM
