old LHV Electronics Turbo Timer work on 06?
Old Apr 8, 2007 | 07:07 PM
04ctd's Avatar
old LHV Electronics "cool-down timer" work on 06?
bought and gave away a used "cool-down timer" few years ago, and got it back, guy never used it. no instructions.
the link on the box www.cool-downtimer.com is not found.
https://www.dieseltruckresource.com/...prog=1&lang=en
that link is about all that still exists on the 'net.
It consists of a hot wire, ground wire, a signal wire, and fuse taps for each wire. For the power source to the box, I used the #6 fuse on the fuse block which is hot at all times. For the
signal wire (blue), fuse #13 should be used for 89-91 models and fuse #3 is used for 92-93 model trucks. This wire is what will deliver power to the fuel shutoff solenoid after the ignition has been turned off. For the
ground wire (green), you have two choices, you can either ground
tks
Old Apr 8, 2007 | 11:31 PM
53 willys's Avatar
if I remember right the green on my 01 went to the Ebrake switch...so if the truck was running and u pulled the Ebrake (off) it would kill the truck
Old Apr 9, 2007 | 02:50 PM
04ctd's Avatar
nah, this one ain't that complicated.
it's simply a 12v "egg timer"
guess i will put it in the classifieds for a 1st Gen guy.
Old Apr 9, 2007 | 02:52 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Yep green go's to the parking brake
Dodgezilla
Nov 6, 2011 04:13 AM
06RAMCTD
Nov 6, 2009 11:35 AM
chariotdriver
Oct 18, 2008 10:50 PM
CTDPower11
Jan 23, 2007 09:29 AM
TripleBquad
13
Nov 20, 2006 02:59 PM
